- 7:04 AM
- Jan 14, 2016
- North western Ohio
You can drill concrete or cinder block with a regular drill but it will take you forever .is a "hammer drill" even entirely necessary?
Now hammer drills I have several. The 18 volt DeWalt is okay if you only have a few anchors to set .Then it's a Milwaukee corded 1/2" ..Then come two Hilti drills ,one medium size that uses sds bits and and a large one TE 80 that uses sds max bits .The large drill will run a 6" core bit which I don't have .Both the Hilti's can be used as a chisel . BTW The Hilti's were another "scrap pass " thing I found in the dumpster and repaired .
