bigbadbob
- 6:30 AM
- Jan 9, 2016
- Interior BC Canada
Doing any mods or conversions to it?
So pulled the muff,,removed the tube thingy, snipped the ex outlet cover to a much larger size. Went to remove limiters, H was gone so did the low, tuned it, sounds good. No wood here in the city,,,They could have changed but on the 490 muffs I’ve done all you do is pull the muff, remove deflector, then remove restrictor tube. Then open exhaust port a bit and you’re done.
Test it later.
There was zero carbon or even traces of it on the ex port, still aluminum color,, slug was as new.
