Skiptooth Fred
- 4:43 AM
- Jul 16, 2022
- Australia
25I switched to 25° and never turned back.
What a revelation in cutter endurance with little to no loss of cutting speed.
Talking 3/8" in Turkey Oak/hardwood
I have a couple short loops of that stuff!
Yeah, it's a power hog and slow.
no its not a hardness factor as in tallowood, bluegums, blackbutt, ironbark, mahogany, turpentine, oak etc. When they poison the crack willow here it completely changes the structure of the timber, it becomes like a rather almost rubbery wood, its really sucks the power out of a saw, if rakers are a bit low like i run in hardwood it bites real hard and if you dont have the grunt then you cant run them like that, i dont like chains not run this way, i dont have time when falling them to be waiting around for a saw that has to be held back when theres hundreds to go down in a day. This timber is always covered in fine grit and sand from floods in the thick bark too. Plenty of faults, defects and dangerous fractures, a happy saw in the hand plays a major part at the end of a day. It also is hard to describe but its somewhat feathery/fluffy in that it seems to always stay in contact with the chains side plates and bar, not unlike being in that thick bark of a hardwood all the time, which results in a hotter running bar and chain, hardwood does not do this. iso150 bar oil is useless in these conditions you need 220iso. Been on saws pro for close on forty years and no hardwood i have ever cut is as ‘hard on the saw, bars or chain’ as this flood level poisoned stuff, am not referring to timber hardness. Normally willow is like cutting something that dont exist! The 592 and 36” duralite excels in this hard environment far beyond my 660magnum, i wont it use unless a last resort, always fight with it under these circumstances. It has nothing to do with timber density and hardwood as you and I would know it. Its all about saw power and ergonomics. Note, its a feral noxious willow variety we have here and its the poison that creates an issue then down the track. Understand fully where you are coming fromWhat hardwoods have to cut? Something is wrong if ya think Willow is harder than our hard hardwoods. Even our Cypress Pine is twice as hard as Willow and Willow is also weak and brittle.
Get amongst it with good gear and a sharp skip
