backhoelover
I like tools
- 9:53 AM
- Feb 10, 2016
- lincolnton nc
have some question about glow plug compression tester adapter
glow plug adapter has shrader valve in it will it work for leak down tester if i take it out?
You can take the schrader out and use it to pressurize the cylinder. A true leakdown kit has a regulator and a gauge to measure the percentage lost.
What compression numbers are you seeing? How even across the 3(?).
here is the leak down tester i have do you think it will work?
http://www.mactools.com/en-us/Speci...ng-Tools/CLD210MA/Cylinder-Leak-Down-Detector
