could a diesel mech answer a few question for a newb trying to learn
srcarr52
1:15 AM
Iowa City
For what engine? Seems like they are all different, some old Fords have to be checked through the injector bore.
backhoelover
I like tools
1:15 AM
lincolnton nc
glow plug adapter has shrader valve in it will it work for leak down tester if i take it out?
Wagnerwerks
1:15 AM
Pa
What compression numbers are you seeing? How even across the 3(?).
srcarr52
1:15 AM
Iowa City
You can take the schrader out and use it to pressurize the cylinder. A true leakdown kit has a regulator and a gauge to measure the percentage lost.
backhoelover
I like tools
1:15 AM
lincolnton nc
backhoelover
I like tools
1:15 AM
lincolnton nc
not yet. i bought a compression tester for hf and it did have the right 8mm glow plug adapter in it. believe it or not i got the adapter from wal mart lol. when i got the adapter it didnt fit the hf gauge quick connect, so i went and bought the one briggs offers and it does fit the adapter. i have also bought the fittings so that i can hook the adapter to my leak down tester. once i get it built ill send more pic before i use it just to make sure.
you also ask if i did a compression tester is there some info you have for me if so that would be awesome. still kinda new to the diesel world
Wagnerwerks
1:15 AM
Pa
I'm not a kubota guy. I do vw and mercedes diesels. What problems are you having? I don't know what numbers kubotas have but for a Benz I always hope for 400 across the board. For an alh vw I'm hoping for over 500. An engine with a variation of over 50psi is often a rough runner.
I have never done a leak down test.
srcarr52
1:15 AM
Iowa City
backhoelover
I like tools
1:15 AM
lincolnton nc
have a over heating problems. think its the radiator ill send pics in a little.
