Clam shell porting?
paragonbuilder
2:33 PM
Norwich, CT
The spot where scribe is pointing. Is that what you mean may caise a hamg up.
Yes. If the port is wider than the bottom of the skirt, it could drop in. It wouldn't have any support
merc_man
merc_man
2:33 PM
southern ontario
So id be best to not widen the intake side?
Sorry for the dumb question. I just dont wanna ruin anything.
merc_man
merc_man
2:33 PM
southern ontario
This bottom piont (scribe is pointing at) is exacrly in line with edge of port.
Motorhead
Cantre Member
2:33 PM
Tampa Fla.
Most of the time enlarging the top of the venturi,but you gotta make sure the metering jet is letting in enough fuel,sometimes you gotta do a little drilling
1:33 PM
Sounds like I would have to send a carb off
merc_man
merc_man
2:33 PM
southern ontario
Oh it is a echo. Make it breath and let it breath or a good mm and timing advance will wake it up
Iv already did a mm and that helped it a lot. Might shave a little off fly wheel key now too.
I dont think ther is much i can do for porting it. Kind of a bummer but i learned something new to look for.
