circle crank ms660
Miller Mod Saws
Chainsaw Masseuse
4:52 PM
Ravenwood,MO
I have thought about using a 385 piston.
I don't have a laptop but if ya do you can look up the pistion specs at baileys. But i think the 385 has longer skirts. If it has a taller top ya might not have to do so much jug work. The 056 looks a lot the same as the 385.
Miller Mod Saws
Chainsaw Masseuse
4:52 PM
Ravenwood,MO
Maybe I'm thinking off to but if ya didn't half to take so much off the base wouldn't that add case volume? :)
jmssaws
Banneded
4:52 PM
It seemed like it had a narrow skirt compared to the 288 piston.
I can't remember exactly but there's a reason I used a 288
awol
4:52 PM
Cabool, MO.
The 385 is a bottom feeder, so its piston has skirts all the way around, these would block off the lowers of a middle fed saw like 066. A better possibility would be a 288 piston in a 385!
MG2186
4:52 PM
Summer,IA
The pin height is different on a 385 being the 288 has more stroke, would that be the reason?
jmssaws
Banneded
4:52 PM
That's why I didn't use it. Thanks alan
MG2186
4:52 PM
Summer,IA
Sounds like something you should try with a longer rod to compensate the pin height difference!
awol
4:52 PM
Cabool, MO.
The 281s skirt wont quite clear the crank throws, have to machine a little off. The jug also has to be dropped quite a bit, so the intake duration is longer than what a work saw needs.
