- 12:40 AM
- Jan 24, 2018
- Extreme Southeast CA
Thanks. I have some Carlton or something I got from @Cat 525 that has less hook I will try.Round file? Hold the file so it’s pressing into the top cutter more and not cutting out underneath it as much. In other words, less hook.
Thanks never heard of it befor. Must be quite a hard wood thenSorry, Eucalyptus. Mouthful to say or type. Then again, my phone has predictive text if I’d use it...
Somewhere here I have vids of MMWS 6100 in it.Thanks never heard of it befor. Must be quite a hard wood then
Carlton is good chain, I run it on my 36" setup.Thanks. I have some Carlton or something I got from @Cat 525 that has less hook I will try.
Being it is all I cut what saw are you running .
My 084 with a 36" 404 semi chisel full comp with plenty of hook runs smooth in that nasty dirty stuff. RM type chain. Not too aggressive but you can stick it when dogging in bucking.Thanks, that makes sense. Have used the 6100 the most, noticed the chatter most with it, and it is a snotty hi speed little sucker. I will try the full comp semi on the 395.
I will try to get stuff ready and together tonight and maybe put saws in it tomorrow for a bit after work before it gets dark. If I can get the 2166 sorted, I’ve been wanted to compare it to the 6100, and try the 24” on the 6100....not buried in that euc, haha.
I use dura-cut Oregon on 40yr old black locust fence posts I get from the farm. Its smoother? Than most and lasts a little bit longer.
