Keith Gandy
Maxima K2 40:1 87 Pump Gas
- 11:55 PM
- Dec 30, 2015
- Provencal, Louisiana
I think so. When the charge starts in it is probably acting sorta like a venturi effect and taking a deep breath and creates negative pressure/vaccum at the intake port exit or negative pressure in the combustion chamber . Too much back pressure would damper that venturi effect? After theres a reduction in back pressure and a negative pressure then the full blunt of the case compression will be enough to transfer the charge and blow the exhaust on out? Im seeing getting the exhaust/blowdown and intake out of wack with each other pretty easily? Just a few ideas I have been ponderingCould the Venturi effect be how it overcomes exhaust pressure initially?
Easy there, big fella. Mike Lee's gonna go all Appalachian American on yer assWtf is a dolmar? Is it a bread making machine? Feminine deodorant?
The lowers are filled and my 66 runs great and has bigger fingers than it.Some epoxy might bring it back J, those are some huge fingers
what do those fingers do ya cut in.The lowers are filled and my 66 runs great and has bigger fingers than it.
It ran terrible before fingers, the transfers are to high,I'm going to try some more intake,it's 80
Fingers are at 113 mains 115
Direction mainly but I suppose it will help filling the cylinder with fresh charge.what do those fingers do ya cut in.
New to porting Just trying to learn. never seen that before.
I would think a progressive transfer would achieve the same as a finger?Direction mainly but I suppose it will help filling the cylinder with fresh charge.
I've had them work and I've had them do nothing,I probably won't use them anymore.
The last couple I've done had no fingers or bridges and ran great.
I think if they work then your transfers are off a little.
Or a bridge should achieve basically what a finger is?
Id probably say lost velocity and very quick to progress backwacks instead of gaining. Ive been thinking lately on 25% of the transfer on the intake side adjusted to desired port # and leave the other close to factory?So.... What if you had bridges, fingers, and sloped uppers?
