Chainsaw Porting Theory
3:15 PM
Exactly.
I've seen some horrible looking gouged out transfer ports in engines that run like hell. No thought at all but into the angles.....and the heights all over the place.
Sometimes I wonder why I try so hard......
When you start thinking of the motor dynamically, more than as one combustion cycle at a time, transfer angles begin to seem more important.
3:15 PM
Which one creates what kind of power I have no idea...
I think the answer is the one that creates the largest transfer area that purges the cylinder the best.
This is where the confusion lies.
Where is the dead space? How do we fill it most effectively?
Keith Gandy
Maxima K2 40:1 87 Pump Gas
2:15 PM
Provencal, Louisiana
I'm particularly interested in the upper entry pockets.
The higher one takes a transfer over stock, the more the entry angle is going to change over what the factory gave us.
There's an old diagram, I'm sure Jeremy @Adirondackstihl has it, that shows 90* vs. angled entry transfers. IIRC, the closer to 90* you get, the peakier but more powerful you get.
The factory quad setups seem to favor a 90* entry in the mains/exhaust side port that opens before the secondaries. So they angle the transfer tunnel towards the intake, but they open it squarely across the piston crown on the exhaust side first.
So has anyone experimented with different pocket entry angles?
I think Mdavlee has
Keith Gandy
2:15 PM
Im thinkin a balance of velocity between the transfers and exhaust. Both tuned proportionally between different models of saws
Stihlbro
3:15 PM
Virginia
Transfers are the "Napoleon dynamite" of chainsaw porting. When you think you got them figured-out, they do totally different. As Mastermind said in regards to entry angles, I've witnessed it as well. As Wigglesworth stated opening points, I've seen that too. I don t understand it but it works!! And that goes against all the talk on any reading material available. I'll end this post with this, I think there is too much jibberish on timing numbers than actual testing of porting. But please continue the discussion.
2:15 PM
I love Neapolitan......
3:15 PM
You don't want it totally flat deep in the transfer if you can help it. That creates a dead space for flow.
czar800
3:15 PM
Ellwood City
Its raining today and I've had too much time to think so bear with me as I think through this.
I've read that transfer pressure is low like 10psi or less? Why not try and gain more pressure...by filling stuffing the uppers with JB and shaping it all towards the intake more like a nozzle shape?
In my limit understanding a few psi could increase velocity or just and a turbo!!!
jmssaws
Banneded
2:15 PM
Circle crank.
Danders
12:15 PM
Forest Grove, OR
Circle crank.
Yep. The saw manufacturers have done a pretty good job though of minimizing case volume compared to what I remember from my early 70's dirt bike crankcases. Which isn't to say it can't be improved upon.
I wonder if part of the complexity of figuring out why different transfers can achieve good results is the interaction with the exhaust port. The engine is inhaling and exhaling at the same time, we try to quantify that with transfer timing and blowdown but we're missing something to explain why 2 saws with the same numbers run differently.
