- 2:01 AM
- Dec 29, 2015
- Strong Island NY
Fascinating stuff for sure.
If you're getting less fuel in and less out, how does a full circle crank produce more power? More RPM from the same saw? It has to be.
It seems like the 044/046 hybrid might unlock some on the full circle crank secrets. There you have a tighter than normal case on a cylinder. It seems to want to pull rpm and likes different timing.
FWIW Jason, I see tons of case compression, but a lower volume. I bet u need lower physical transfers. If you increase the intake, you'll probably get tons of spitback and negate the effects of all that work. It should need less, not more time to fill the case.
Making more power has to be more work over time, so an increase in RPM.
