Chainsaw Porting Theory
Brewz
4:56 PM
Hunter Valley - Australia
And this brings me back to my question on exhaust size on the muffler side
Are we better off making the port mouth outlet bigger to get a faster drop in pressure over distance as the gas leaves the chamber as opposed to making the port wider
Perhaps porting is better done after the piston side port?
12:56 AM
Whatcha talking about Willis?
Keith Gandy
Maxima K2 40:1 87 Pump Gas
11:56 PM
Provencal, Louisiana
At least in a 4 stroke, the exhaust valve is much smaller than the intake because of the pressures that pushing gasses through them. The exhaust flows by pressure, the intake vacuum. Even though the volume of gas is much more, it can flow though a smaller area.
In a chainsaw, I've seen it quoted that 90% of the exhaust gas pressure/flow is gone in the first 10* of port opening. If I'm wrong on this, please offer the correct info.
So if 90% is gone in 10*, why risk catching a ring with a wider exhaust?
I guess I'm trying to ask if it actually does much and if the benefit of widening outweighs the risk for this port.
Square the top up as much as possible, increase port window duration just short of freeport, add a stepdown exhaust if needed? Just ideas
12:56 AM
Depends on engine. Almost all I've worked on,IIRC, had a piston crown above the exhaust floor at BDC. So lowering the ex floor would do zero.
Keith Gandy
11:56 PM
I have a 390xp with a stepdown exhaust thats opened up pretty good that is a runnin son of a gun but also pulls 28 404 buried very well. Exhaust hasnt been widened
Keith Gandy
11:56 PM
A wider exhaust will evacuate the exhaust gas quicker than a taller narrower one. It won't be much of a difference but the last 10% is hardest to gain.
Im believer in at 1st crack of the ex. Port is where most of the flow will happen with the most velocity so widening the top or squaring as much as safely can be done is where its at
Brewz
4:56 PM
So pressure V's volume would indicate more compression will benefit from a wider port
Moparmyway
Its just a saw
12:56 AM
In a meeting
So far, on any Stihl 70cc-90cc that I have ever seen, you really cant go to big on the exhaust opening in the muffler.
They like them big, matter of fact, the bigger you go, the more power they have in the cut
The ported ones really come alive with a second large opening, like @Red97 makes
REDs deflector.jpg muffler exit with REDs deflector.jpg IMG_2600.JPG IMG_2587.JPG
11:56 PM
Mike says a lot here.....and with only a few words.
I've not been posting much. But I'm still reading along. Just trying to get some work done.
shorthunter
11:56 PM
West Central Missouri
Thinking laterally, by the time the piston gets to a point where the wider ports are taking effect, the exhaust port it probably 10 to 20% open and the transfers are opening or open.
So is a wider evhaust port going to increase performance at this point?
Yes
Redfin
Meh...
12:56 AM
Central Pa
Ive never measured but now im wondering in a stock saw how much the physical area the ex and trans relate to each other.
In my head the ex area doesnt need to be to terribly much larger than trans. Considering most is expellend very soon at first opening.
