- 12:27 AM
- Dec 3, 2015
- Banner Springs Tennessee
I've been too busy to post much.
People who think that are right in that raising the exhaust almost always increases HP. However, in many cases it also significantly narrows the torque curve and leads to a saw that screams during light load, but falls on its face in a decent cut. The Stihl ms 260 comes to mind. I didn't know the exhaust port timing numbers for this saw, but I could tell that it had to much exhaust port height and not enough transfer duct volume just by the way it felt. Subsequently one of the builders confirmed from this site confirmed my suspicion.A few years ago all the pundits were saying raise the exhaust........always raise it.
My how things change.
Ye old fart knocker!!!! Cattle baron!!! fence mender, hay stacker,,, bull chip spreader,,,, Etc. Etc.I've been too busy to post much.
Most of the stihls have piston skirts that are to narrow to get 70% on the exhaust,Ok I'm sure it's probably been answered but what are we going for when we widen the exhaust and intake? Are we going for a cooler running engine by getting the hot exhaust out quicker and cool air and fuel in at a faster rate? Or are we going for more rpm or torque?
Also how do you go about measuring how wide to open the port. I've heard 65-70% of bore but how is that measured, total actual width or on the curve of the wall?
That depends on the saw. The intake needs it on some and not others,the exhaust on a some huskys is already Close to 70%So what you are saying is I'm best to leave the intake alone and only widen the exhaust. At this point I'm not looking at raising or lowering anything. Will widening it give me more torque or just higher revs that give you more momentum?
Which way, widen it? If so by how much?I think more intake will help you.
You can actually measure all the ports with a micro ruler before you grind so you know how far you've went. If a stock exhaust is 102° then removing the base gasket that's .020 thick will lower it about 1.33 degrees. Removing gaskets, depending on how thick they are, can lower ports anywhere from about 1° to 2.75°. Measure the gasket you're removing and raise the ports that exact amount to maintain stock numbers.I was trying to keep my numbers close to stock and I didn't have a degree well at the time. I am aware that by lowering the jug I increased intake duration but most other timing should be close to stock I would guess.
Lower.Which way, widen it? If so by how much?
