Chain talk
Red97
2:16 AM
MI
One of these days, I'll attempt square filing. May just wait out a good square grinder lol...
I have patience for certain things, not sure if chain filing it one of em.
1:16 AM
I'm not ever going to be a square filer.....it's just not on my list of stuff I have time for.
CR888
6:16 PM
I love a good square filed chain but until I have a Simington work chains are round ground off the 511. I somtimes hand file square but that's for fun not work. At the end of the day spending ya nights hand filing opposed to 20mins doing chains on a grinder gets old fast.
greendohn
firewood hack
2:16 AM
east central indiana
I tried a few tips and tricks from a thread on AS,,I think it was Andydodgegeek started it a couple years ago.
(I use an old Foley Belsaw grinder.)
Full skip chain, knocked the rakers back and thinned them, and took a little out of the tie straps on the top edge, think a figure 8 lying horizontal, and changed from 32 degrees to something like 22 1/2 degrees.
^^these details are from a couple years ago^^ and may not be accurate on the angles.
Anywho,,24" b/c combo with the mod. chain on an approximately 20" pignut Hickory and was making like 10-12 seconds cuts,,very fast to this firewood hack.
It dulled very quickly and was the end of my modifying chains.
What I took away from the thread and my playing around was, making room for the chips to clear is the joo-joo in making a faster chain.
I dunno.
junkman
Crush it
11:16 PM
pacific northwest
Once the chain is filed once to fit the contour of your file ,2-3 light swipes will "touch it up" every couple of tanks .
Here is a demo vid i tried a while back ,was kinda blurry at end though .,Not really any slower to file than round in my opinion .
And here is the same chain from vid in a photo ,notice the side of the cutter is up and down ,i aim for this angle in square ,it is smoother than a hook is ,it slices instead of tearing the wood this way
Edit :,the up and down side cutter also makes the outer corner stronger ,because it is not so pointy and fragile ,i bet my top plates are in the 15-20 degree range also if i measured them instead of traditional 30 people use .
junkman
Crush it
11:16 PM
pacific northwest
This one is pretty rough in the cut.
Looks like a racing chain though .
I run a 32 inch bar on a stihl 440 chassis with a 460 cylinder ,the less hook the better to keep the power up in the cut for work ,it still cuts plenty fast ,i can actually get a good solid 2-3 hours sometimes on one sharpen as long as wood is clean ,not swapping chains all the time is more important than a second in a cut to me ,i also run tall rakes ,i hear of guys taking 2 swipes on a new chain ,that makes me cringe ,just a bandaid to make it cut faster in my opinion ,i hate a grabby pulling chain ,when the chips get 3/4 to an inch long i file the rakes 2 swipes ,normally do not touch them for 3-5 sharpens ,depending how much it takes to clean the chain on the grinder .Full skip also helps lower powered saws pull a longer bar ,i mainly like the skip on long bars because less teeth to sharpen .I do not normally touch the gullets on square till have 3-4 sharpens also ,a waste of time in my opinion to do every sharpen .
malk315
Running Saws for Therapy
2:16 AM
Lancaster, MA
I would recommend homelite410 vice to anyone attempting square ground . His vice works awesome ! @Homelite410
I second this! I'm only doing round file, but when filing w/ saw bar in a vise the powerhead can affect me by being in the way in one direction along w/ me being a lefty it compounds the problem. Bar in the other direction is my strong side -- can end up taking more off teeth on strong side. When I want to get a really good edge I take the chain off and use the @Homelite410 chain vise -- it helps to have less of strong/weak side and the teeth are held super rigid so you get much more precise with each stroke. I file every time I go out -- on the bar when in a hurry. When a chain takes a hit (staples or nails or whatever in yard trees) I get out my trusty @Homelite410 vise and have at it. I use a husky roller guide for angle and depth in the gullet and the vise has a relief cut so the roller guide can fit. Also use oregon center drop depth gauge tool at 0.025 but take a little more off when cutting pine. Get nice big chips out of my 262 and 372... nothing more satisfying than a pile of chips and a saw that self feeds... some norway maple was cutting real nice last weekend.
