- 2:57 AM
- Feb 4, 2017
- Winona County, MN
The question nobody is asking: are ported saws harder on chains, specifically cutter life?
As we already know, chains are not created equal. Different brands source different alloys to manufacture with. That being said, cutters are subject to a wide variety of cutting conditions. So everyone’s results vary greatly, even with the same chain.
I’ve been pondering in my head that chain life is probably reduced when ported saws are powering them, on the larger end of the saw cc’s scale. For this question, let’s focus on 70cc’s and above.
Ported saws are typically pulling harder and maintaining higher rpm’s in the cut. This is obviously forcing the chain through the wood faster, and more aggressively than it would otherwise. Faster equaling more heat and friction. Heat being the enemy of just about everything on this planet when it comes to wear associated with use.
Maybe a ported saw doesn’t affect it enough to matter, maybe it does..
Thoughts? Questions? Have at it - let’s see what everyone thinks..
