Chain grinding and filing thread
12:57 AM
If I get a chance, I will fire it up tomorrow. The 261cm. I don't think I have even broken it in yet. Lol
junkman
Crush it
9:57 PM
pacific northwest
Look at the edges of this cutter ,crisp and clean ,no spoon left on the top ,this is grinding into good meat i call it ,when your chain is rocked out ,it takes a lot of removal to get the cutter looking like this again ,also the cutter is smooth on the faces ,no chatter marks from pushing too hard with the file ,it does not take a heavy hand to sharpen chain ,let the file or the grinding wheel do the work ,not your heavy fist .
Duane(Pa)
It's the chain...
12:57 AM
Centre County
John Reilly says "YOU" should be in charge of the file. LOL
Make the file so what you want it to do. Lol
Just funnin ya Brian
He is meaning about where you are holding/positioning it....like not letting it skate around and find it's own path. Make it go where you want... letting the teeth do the work
12:57 AM
This 261 has a small tank. Probably be about that. Hasn't really loosened up at all yet. I gotta run it some more.
12:57 AM
I was just funnin Brian. Lol
You're right though.
Duane(Pa)
It's the chain...
12:57 AM
Centre County
Check out the angles under the top plate. For milling, you would want that pretty steep. The one Wolverine posted is full race, a hard knot would wreck that. For cords of firewood, something in the middle ground will cut a sh1t ton of wood and still stay sharp.
Chainsaw Jim
Con Artist LLC
9:57 PM
Springfield Oregon
I have to agree with John Riley on this one...and finish with junkmans advice.
What I'm assuming John is implying is when you're not firm and strong handed it will lessen the life of the file. You don't want it too squeak or skip away without biting metal because it will quickly dull. I start with a couple good firm swipes, then relax and let the file do the finish work for a glass smooth finish on the cutter.
12:57 AM
Thank you Duane. I just learned my new tip for the day. [emoji106]
Thank you too Jim. [emoji106]
I really do appreciate the feedback.
junkman
Crush it
9:57 PM
pacific northwest
The lighter touch for the sharper chain is what i was trying to put into words ,a heavy fisted filer will get some chatter ,and the sharp edge of the cutter will be rougher than a lighter sharpen .
wcorey
12:57 AM
ma usa
And when you get chatter, you knock teeth off the corner of the file.
Then the file is pretty much done, starts catching on the corner of the cutter.
Biggest culprit for chatter is not having the cutter clamped in rock solid.
12:57 AM
The teeth cut very well, but it seems I just missed the corner a slight bit.
Thanks for the feedback.
I still hack away, continuously learning this square file. I converted this chain from round to square. Lol
Nothing wrong with that cutter, like Matt said.
When Dallas first got his grinder, he sent me a chain to try. I had to either dog in or take the rakers down to .035 to get an 044 to cut. That chain would go I bet 5 tanks in clean hardwood before a touch-up. Great work chain
Chainsaw Jim
Con Artist LLC
9:57 PM
Springfield Oregon
We're on the same page bud. Most folks can't get the angle perfect to start with and it takes a little more pressure to get the file to dig in.
Hedgerow
11:57 PM
So, did Dallas ever run his chain??
I never heard anything from him..
