Chain grinding and filing thread
brshephard
Stihl saws, Husky women
3:02 AM
MT
It's like a hybrid. You get a round filed side plate with a square filed top and corner. Faster than round and supposedly more forgiving than a square file.
Chainsaw Jim
Con Artist LLC
2:02 AM
Springfield Oregon
Whata the double bevel flat file look like. Could you post a pic?
Here's a couple good brands with a Chinese cheapo on the bottom. They run about $12 each, the pig metal was about $6.50.
Chainsaw Jim
Con Artist LLC
2:02 AM
Springfield Oregon
Jim which file brand do you get the best life from?
The Portugal ones have lasted longer so far with my learning curve. I've found that all need babied if you want them to last more than one loop if the teeth are beyond a simple touch up. The key to maintaining a good chisel edge is to touch it up more frequently. A 30"or so chain can be touched up by a skilled person in less than 5 minutes.
For very dull or rocked teeth my advice is to have a round file on hand to get the profile in check, which also takes care of the gullet, then you'll have a good angle to follow when finishing it with a chisel file.
jakethesnake
I Am The Snake
5:02 AM
Here & Now
Where you find that Chinese fella at?
Armbru84
Just trying to get by
5:02 AM
Michigan
Sty57
4:02 AM
Land of Cheese & Beer
Where do you guys get the 6 sided files for square chain and whats a good price? I would like to try.
Do saw dealers carry it?
My dealer has them on hand at all times, I think the last ones I got were in the $11 range.
Khntr85
5:02 AM
Indiana
If you have a round chain and a square chain ground in such a way that they both cut the same speed, the square chain will outlast the round.
Round grind is less efficient and requires more aggressive angles to cut the same speed. A good example of this is off the roll RS. Look at how the working corner sticks out unsupported. Now compare that to RSL with no side plate hook and a conservative top plate angle.
They cut roughly the same speed.
So when someone tells you square dulls quicker, it likely does, but they are comparing it to a 7/32 round filed chain that is quite a bit slower.
Here is my work grind
Note the underside top plate angle. It's about 20°, real aggressive. It lasts me about as long as factory grind RS.
If I was to cut dirty wood I would relax my angles a bit, if that didn't work I would go straight to semi chisel.
It seems that a lot of you guys that have played with the angles all say that a “work” ground square chain will last the same a a RS....
I dont have a square grinder, but I have done a lot of experimenting with angles in the Oregon and USG grinders....
Knowing what the cutters profiles are, I can see why you guys say this....as you stated, the point on the round ground Chains is “unsupported”....
Dammit, every time I get on here I start trying to convince myself to get a square grinder, LMAO....
