CASE VOLUME DISPLACEMENT ? / Introduction
lwhaples
5:40 AM
Vt
Hope to hear all went well.
SHOVELHEAD
5:40 AM
MAINE
Good luck pal
Best of luck with the surgery!
Just wanted to say thank you to you all.
Well I'm still on this side of the Dirt !
I'll be resting for a while now, Till I'm able to move around.
Hoping to have some time in the shop to resume the Builds & start fitment of P&Cs.
I have lots of Ideas! (Thanks Al) 066 piston ! (I have another 2156, maybe 36 stroke)
But still rethinking the carburetor Boot?
I do however want to keep the stock appearance & linkage.
J_M____
5:40 AM
CT
If you make any make any more of those nifty degree wheel holders, let me know. I would be interested in one.
:b1:
SHOVELHEAD
5:40 AM
MAINE
Playing with some #s this morning.
1st is the Displacement of whats currently being Built 72.206 CCs
With & With Out Crank Stuffers.
2nd using 36mm Crank from a 2171 & 272xp Cylinder 76.453 CCs
This is a easy Build & looks like it could be a Hell of a Performer in a Mid weight saw.
Finally #3
$$$ The Money Pit $$$
Using the same 272xp Bored and plated to 54mm would come in @ 82.447CCs
Terry Syd
7:40 PM
Comboyne, NSW Australia
I love this kind of dirty talk. A 60cc engine taken out to 72cc is a 20% increase in displacement. My 365 BB only took the displacement out from 65cc to 77cc, for a 18% increase - heaps more power when everything is feeding it.
So a 60cc engine taken out to 76.5cc is a 27.5% increase. A 60cc engine taken out to 82.5cc is a 37.5% increase.
My best on boring and stroking was taking a 49cc engine out to 104cc, for a 112% increase in displacement. HOWEVER, you have to be able to feed the displacement. The head work (homemade valves, etc) to get that engine to breath was more work than the boring and stroking.
On two-strokes, the size of the transfers becomes the restriction. If you shift the bore out and neglect (let alone restrict) the transfer area, the power will suffer - been there, done that.
I'd go for the 82.5cc engine and work the transfers to feed it.
If you blow it up, consider it a sacrifice to the 'God of Speed'.
mgr1
11:40 AM
Belgium
On all the big bores you reed that they are not stronger than a OEM cylinder because of the smaller than oem transfers volume.
Why runs the Dolmar 166 from @Lee H so good with a 4mm overbore on original transfers?
5:40 AM
For a lot of "big bores", smaller case volume also becomes problematic, resulting in high RPMs, but reduced torque. There is often more to it than just increasing displacement and the corresponding transfers.
This dilemma is common on the 440/460 big bores.
As for Lee's big bore, that saw is an animal, I have run it at GTGs. I also believe he said he did not do any port work to it, truly impressive! (Must be the 880 piston ... Ha, Ha, Ha).
Deets066
AKA Deetsey
5:40 AM
Aftermarket big bores are what you hear about not running as well as stock. A stock cylinder that is bored and plated is another story
mgr1
11:40 AM
Belgium
That is true about the aftermarket ones. Did you ever measure the volume from the transfers between OEM and China?
Terry Syd
7:40 PM
Here's my two cents. The area inside the tunnels will have to be increased. The best way is to WIDEN the tunnels. The reason to widen the tunnels is you can widen the transfer port openings.
Widening the transfer openings is a proportional increase in time/area of the ports. If you widen the ports 10%, you increase the time/area by 10%. (you also do not decrease the INDUCTION STROKE, which occurs from transfer closing to TDC)
If you increase the displacement by 37%, then widening the ports by 37% will keep the time/area of the transfers in the ballpark. However, I'd go smaller to begin with.
Now there is gonna be a problem with high crankcase compression which will push the powerband up and narrow it. Perhaps an open sided piston (windowed) is available.
With the windowed piston you can eliminate much of the side cylinder wall which will increase the case volume. It will also make porting this beast easier.
To help with the porting, I recommend you drill a 1mm hole between all the fins in the port so you can monitor how close you are getting to breaking through. You can watch your progress, when you get about 1mm of wall thickness, then stop and patch up the holes with some GB Weld. You can use a bit of extra GB Weld to help strengthen the cylinder.
