HELP! Can I install the head from an Echo CS4910 on my CS490?
Ed Sybert
Active OPE Member
11:38 PM
Hanover, PA
I have an Echo CS490 in great shape. I'd like to gain the starting help from the decompression valve that the CS4910 has. Is the newer head a direct substitute for the earlier one? Thanks, Ed
Woodpecker
Sassy Madam
11:38 PM
Yes I believe you can. You’ll find one of the best threads on these saws here:
furb
11:38 PM
PA
It should all go together. 490, 4910 and 501 interchange
Ketchup
Epoxy member
9:38 PM
Colorado
490 piston is a bit more restrictive with slightly different timing. If you have the 4910 piston use it.
FergusonTO35
11:38 PM
Boonesborough, KY
Just to put a bug in your ear, the 490 is the economy version of the CS-500P that I have. Kris at S&S Worksaws did a fantastic port and muffler mod job on mine so you might want to hit him up. He is a member here.
