Adamski
Plebus Splederns
- 10:34 PM
- May 3, 2017
- Essex, UK
I feel the need to do a new build thread, nothing special, just an old burnt out 038AV with a good crank and bearings.
Here is the old girl, straight out the box with a fried piston. Pretty dirty but in overall good condition..
A good clean, a spare 52mm cylinder, a meteor piston and a caber ring and this is where I am with the pictures below.
Didn't have to clear the case to cylinder at all as some do but needed to oval out the cylinder bolt holes, I will show these when the top end is off again.
I have P320'd the crankcase since the pictures and it is ready for some 'Ford tractor white' paint.. I am going to leave the case halves together and remove the cylinder, clutch, oiler and all other parts beneath the clutch cover.
Aiming to tape off the flywheel area, the cylinder area, the conrod and most of the area covered by the clutch plate.
The paint is a pretty decent match and is tough as anything out there I have had decent results from this brand before (another image below)
Today I have been going through what I believe to be acceptable AM parts and necessary OEM parts.
Today I have ordered off Huztl the following:
Rear handle/tank assembly (build quality is said to be high on the 038's/MS380's
Top covers till I find decent OEM ones
Front chain brake handle
Wrap handle
Clutch sprocket retaining plate (not sprocket or E clip)
Upper AV mount (as they are gold dust as OEM)
Recoil (I have had an 038 one in the past and it was good from them)
Muffler (easy to mod and pretty much gutted anyway)
Now I am on the hunt for the remaining OEM parts:
Air filter
Bing or Tilly carb
Intake manifold and intake clamp
Impulse hose
Fuel hose
Ignition coil
Fuel and oil caps
Chain adjuster
Clutch cover with the Stihl logo
Lower AV mounts
Obv's a genuine 20" Stihl bar and chain
Anyway, this is where I am. And now I am playing the hunting game for the remaining parts. I am in no hurry so I will be buying as and when.
I will add some pictures of the paint process as I begin it some time this week hopefully.
038 Mag for the win... whoever does not like them needs their heads re-programming..
Wrap handle
Air filter
Bing or Tilly carb
Impulse hose
Fuel hose
Ignition coil
Fuel and oil caps
Chain adjuster
Lower AV mounts
