Brushcutter
jake wells
no longer here
12:13 AM
ky
my fs 130 has a lot of power but you need to use .130 line otherwise line will not last long.
i can mow down johnson grass and shrubs with it. fuel economy is good and i can't hardly feel any vibration.
backhoelover
I like tools
1:13 AM
lincolnton nc
homelite used to have a trimmer that had the super xlao saw that ran a trimmer
ANewSawyer
1:13 AM
Foothills
If you are willing to spend the money, then get the 345fr for doing trees. I wanted one but got the fs240 instead. It was about $200 cheaper but you have to buy all the extras seperate. Download the 345 FR manual. It seems that it comes with tri blade, saw blade, trimmer head, limit stop(dedicated saw blade guard), and a really nice harness. The FS240 you have to buy ANY blades, it does not come with a limit stop and it comes with a $20 harness.
Now, the FS240 is lighter and better suited to BRUSHCUTTING. But if you want the power, go 345FR. It does have better antivib and air filtration at the cost of a more complex internals.
I bought the 240 because it was cheaper. Even though I think it could use a little more power, it matches my needs the most closely of anything I found on the market.
Oh, When I looked at Echos big unit, I was unable to find a grass guard that fit it. It was basicaly limited to saw blade only and no harness.
Nitehawk55
1:13 AM
Ontario
Even with my FR 350 having a flex shaft from the engine to the straight shaft it will drop small trees +2-3 inches with ease and 4" with a bit of work using the circular saw blade .
Small saplings and stemmy weeds I use a grass blade . Goes thru it like you're using a laser sythe !
Keith Gandy
Maxima K2 40:1 87 Pump Gas
12:13 AM
Provencal, Louisiana
What cc?
Nitehawk55
1:13 AM
Ontario
36.6cc but it sure seems like more .
Go as light as you can Keith , they get heavy after a while and get the best harness you can too .
Nitehawk55
1:13 AM
Ontario
That will work ! I got one of the FS 450 test units when I worked at Stihl , these had been out in the bush and had quite a few hours on them but ran fine .
Did you get the harness with it ?
