Mike C.
- 5:01 AM
- Jun 24, 2020
- New Hampshire
Hi guys.
I bought an Echo 2620T back in June to replace a 30 year old Shindaiwa C20 brushcutter/trimmer that was getting very tired.I figured I'd jump up a little in HP(from 21cc-25cc)and I went for the (T) model to get the high-reduction gearhead that everyone's been raving about.
I researched a bunch of different brands and models and eventually chose the Echo for what seemed like good reasons.So far,for regular trimming,I am pretty happy with it.It runs good,has plenty of power and appears well made.One thing I don't like is it feels rather heavier than the spec sheet would lead one to believe and it doesn't do much good for a shoulder injury I got back this winter.I think going away from the bike-handle design was my first mistake,but the high-reduction gearhead isn't offered in a bike-handle configuration.
Today I started a miserable weed-wacking/brushcutting job that I do for a gent every year at the end of August-about 35 hours worth.I brought my new Echo to his house to give it a real test-grass 2-3 feet high and thick like the hair on a dogs back.Well,I can't say as I was too impressed with the way the Echo handled it.It took a lot more work to knock that stuff down than I thought it would.The engine didn't bog,it just struggled to cut the stuff.I had to keep going back over it,again and again.
Then,unexpectedly,the customer shows up and offers to let me use his Stihl FS-110 with bike handles.He bought it about three or four years ago because I told him my Shindaiwa was on the verge of death and he didn't own a decent trimmer.I even suggested he buy the Stihl as they had a good reputation and a good dealership close by.
Well,I decided to do a comparison with my Echo on that tall grass,using the same .095 string ,and I have to say the Stihl kicked the chit out of my Echo.It blasted through that grass considerably easier and was way more comfortable for me with my F'd up shoulder.
I really thought the Echo would be serious competition for the Stihl considering the two engines are almost identical in HP.I thought the Echo could compensate for the torque of the Stihl's 4-mix engine with the high-reduction gearbox,but not so-it was seriously outclassed by the Stihl.It even feels lighter than the Echo and ,on paper,it's not supposed to be.
Is it possible that the high-reduction gearbox is more of a hindrance than a help?Would the standard gearbox from the non-T version produce more output shaft RPMs and actually cut better?
I ordered the blade conversion kit for the Echo,it should be here this week.I think I'm going to save the Echo for the larger-diameter stuff that needs a blade and stick with the Stihl for the grass,it does it so easily.
I shied away from buying a Stihl because of the electronic carb BS they implemented on the new models and the plastic cams don't turn me on.But,my friend is notoriously bad about performing any maintenance on any equipment he owns,the FS110 included,and besides having to have a new carb installed at the end of the first month of use,it has run flawlessly.
Hindsight being 20/20,I think I should have gone with a Stihl.
