Blackstone griddle
calcutta250
5:43 PM
SC
I have the small one. It is nice but you have to maintain the griddle. It might be worse for me in SC. And you’ll use a lot of oil.
One thing that is interesting is restaurants scrub their griddles to shiny. But the blackstone seems to not “require” that. I think you’ll need a lot of oil regardless.
They are nice though.
ammoaddict
5:43 PM
Granite Falls, NC
The shiny ones I've seen in restaurants are stainless steel. Once you get a good seasoning layer built up on the Blackstone, it really doesn't need that much oil. It is a pain that you have to clean it every time you finish cooking and then re oil it. It doesn't take long once you get the hang of it. I really like it. I got it the end of February and the second tank of gas is nearly empty.
calcutta250
5:43 PM
SC
Stainless steel in normal cooking vessels are inherently known for stick. The remedy for that is a lot of oil so there is a layer of hot oil to stop the food products from sticking. Fry an egg in a stainless steel skillet and it becomes very obvious.
My seasoning was done properly. I also oiled it regularly. Then I forgot to oil it and the oil had thickened to where I had to heat it up and scrape it all off.
My experience from restaurants, watching cooks at work on pro equipment, and my little blackstone. You’ll need a lot of oil.
That is just my experience. Good discussion!
ammoaddict
5:43 PM
Granite Falls, NC
Yes stainless steel does stick but Blackstones are not stainless steel. They are more like a cast iron skillet. They have a video that shows you how to season it. They stress very THIN coat oil oil. Heat it up, let it cool and THIN coat of oil and repeat 3 or 4 times. If the oil layer is too thick it will do as you described. I have done that with cast iron skillets. Too thick of seasoning layer and it will become tacky and food will stick.
ammoaddict
5:43 PM
Granite Falls, NC
I use mine way more than I expected. I even plan on getting a smaller portable griddle to take with us while camping.
There are very few things you can do on a gas grill that you can't do on a blackstone. I use mine at least twice a week, sometimes a lot more. I keep forgetting to take pics to post on here.
