Bernie’s MS250 Upgrade
GMB74
11:47 AM
Vermont
This might be a good upgrade if you are playing with the timing.
I DOUBLE DOG DARE YOU!
Clip 1128 195 3500
Dog (pawl) 1125 195 7200
GMB74
11:47 AM
Vermont
The chain catcher is a small arm of plastic coming off the clutch cover.
It works OK the first couple of times you lose your chain, then breaks off the cover.
Replacement chain catcher 1123 656 7700
GMB74
11:47 AM
Vermont
The OEM high output oiler is over $46 at my local dealer.
Do the AM Chinese ones work or are they junk?
I run a 16" bar on mine, the factory oiler works fine for that.
MAF143
11:47 AM
North Central Ohio
I've done the same MM they mentioned above, timing advance, dual pawls on the starter, and run full chisel square file chain on an 18" bar. With the MM it took about half a turn out on the high jet and it is a whole different saw than stock. The oiler on mine seems just fine as long as you keep the bar clean. I clean and flip mine every 3 tanks anyway. Air filter isn't very impressive so I grease the sealing points and run the AM nylon mesh style. I also run an 8 tooth rim sprocket. It'll throw a pretty serious shower of chips for a saw this size with this set up.
After market felling dogs are handy for me as I use it to girdle a lot of trees as well. Those aren't really needed for most stuff on a saw this size, but it is nice for girdling.
I've been very happy with it over the years, however if I was buying a new saw, I think there are other saws out there that are a touch lighter with the same power. I won't spend money to replace it though unless there is a major catastrophe... It gets used a lot in my woods and always delivers what I ask of it.
PA Dan
FYD
11:47 AM
White Oak PA
What's the part number?
DND 9000
5:47 PM
Germany
The higher output oiler is 1123 640 3201.
GMB74
11:47 AM
Vermont
It's a sub 50cc homeowner saw. A little timing advance won't make it that much harder to start.
025/MS250 has a reputation of being hard pulling/hard starting in some circles.
I never had a problem with my saws- I have had several- but some people apparently have.
I will give my current one a little TA and see what happens.
PA Dan
FYD
11:47 AM
White Oak PA
A well tuned saw that is treated right should never be hard to start.
GMB74
11:47 AM
Vermont
Well tuned
Treated right
I suspect this is why some people had problems.
These little saws often don't get the respect they deserve.
Another possibility is a faulty part that was never addressed under warranty when new.
5155
11:47 AM
pa
I have this one 55, I need to treat better lol.
Hulpio
DIY addict
6:47 PM
Finland
Replacing original black fuel hose with clear one kind of opened my eyes. I can not expect chainsaw starting easily if it just does not have fuel. Could be a Husky disease could not, do not know.
sawmikaze
11:47 AM
steeltown
Well tuned
Treated right
They have a quiet cough on choke and a lot of people who don't know much about chainsaws keep pulling and flood them.
I never gave a cold one more than 3 or 4 yanks before I moved it up to half, never had a problem.
sawmikaze
11:47 AM
steeltown
Well tuned
Treated right
They can last a couple seasons under heavy commercial use. For a seasonal firewood cutter a long time.
GMB74
11:47 AM
Vermont
I cut my yearly supply of firewood with an 025 for 10-15 years before getting an MS250.
The 025 still ran great, but the MS250 was on sale at the dealership where I worked and the rumor was they were going to stop production.
I figured I should upgrade while I could.
That was almost 10 years ago now.
I have bigger and better saws for bigger work, but the MS250 is the one I grab first for most jobs.
Loony661
462’s 4-LIFE
10:47 AM
Winona County, MN
This. Then they blame the saw for not being adjusted correctly or being junk… In reality, one of the toughest “homeowner” saws made IMO.
GMB74
11:47 AM
Vermont
A "quiet cough" is right.
They will crank it over until they have gas running out of the muffler or it hydrolocks, then bring it back saying it's junk.
I would take the saw out back, clear it out then instruct the new owner (again) on the correct starting procedure.
