Warped5
- 3:50 AM
- Jan 7, 2016
- Northwest IN
To hold it in place or for leaks?
Yes
He is good he dont need to hold it in place he is accurate. And it wont leak with a gasket without a sealer. The gasket is enough.
If you use oem tools to assemble they pull the crank through the bearing.
I have the 1128 one. I'd like to have a few more. I can drop bearings in and then reheat the case and bearing and push it in by hand 90% of the time. The circlip tool is the one I really wantI know how the OEM tools work. And I imagine Scott has them in a drawer or box somewhere.
I'd put my money toward the seal installation tools, myself.
You have trouble with those clips huh? Do you find the bigger ones or the smaller ones harder?I have the 1128 one. I'd like to have a few more. I can drop bearings in and then reheat the case and bearing and push it in by hand 90% of the time. The circlip tool is the one I really want
There is definitely a trick to it.My finger says yes. 1 out of 3 result in blood. Husky makes it nice with the wings.
Let me know if you wanna try one out.I have the 1128 one. I'd like to have a few more. I can drop bearings in and then reheat the case and bearing and push it in by hand 90% of the time. The circlip tool is the one I really want
I've got the 12mm & 13mm onesThe circlip tool is the one I really want
They work great !!
Got them from DD
Yup, they certainly are SirAre they the Stihl OEM tool?
+ 1 exactly how I do it works a treat never had an issueI use a cheap toaster oven, heat the cc half at 350 for 30 mins, and freeze the bearing, they drop right in.
....... Gonna try the heat gun for the case halves to install the crank to see if I can get a feel for that. Usually use the toaster oven approach.
your not alone. I have tried the heat gun off and on over the last few years, i keep returning to the toaster oven because it is easier and i like the idea of heating the whole case instead of localized heating with a heat gun.Toaster oven wins..., at least compared to my particular heat gun (typical 1200w Wagner). Just easier and actually faster in my case. Plus it seems to me that uniformly heating the entire case half would logically result in a more uniform fit as everything expands and contracts creating less isolated stress or chance of possible warping. Probably overthinking it a bit there, but heating all the molecules to expand at the same rate and temp would seem to require less heat than just concentrating on a smaller area which would sorta have to push itself up against the colder area to actually expand. Hell, makes sense to me! LOL
Philbert? You out there?![]()
