Archer chain
AuerX
Constantly Confused
3:31 PM
North East
I have no idea whether it's slow or not!
Never heard of "fps" for chainsaw chain speed, only "m/s" - meter per second.
To me FPS is a video gaming world expression.
I simply assumed that a battery powered chainsaw will not achieve the chain speed of a modern 2-stroke chainsaw.
Typo, it's 3,940 FPM which is "Feet per minute" according to Makita spec sheet. https://www.makitatools.com/products/details/XCU04Z
Basically 20 meters/second
blackbruin
Heeeeeeere's Johnny!
3:31 PM
US
I used one loop of archer 3/8 full comp full chisel that was given to me. Dulled faster than normal. Soft cutters the vallorbe files cut it like butter.
The cutters are big and its definately slow
AuerX
Constantly Confused
3:31 PM
North East
Why skip?
My PS-550 pulls 18" Oregon full chisel, full complement fully buried in hardwood no problem.
Because I think a 56cc saw has no business running a 20" bar but it came with it and I like the reach for certain things.
Skip has less teeth to sharpen up and I'm working with dirty stuff on the ground too so it will get dull fairly quick and the reach comes in handy there.
I have no intention of burying it in anything.
I have a Forester 16" bar for it too that will see more use.
I have a 18" Husqvarna X series bar and chain for a 340 too, way too long but great for limbing felled trees.
tek9tim
12:31 PM
Winthrop, WA
I posted these in the square grinder thread a while back, but may as well put my 2 cents in here too. I square ground some full chisel 3/8LP .043 gauge Archer full comp for the Makita battery saws. Since there isn't any port work I can do to those saws, I have to do something to improve the performance. Cuts well, holds an edge well enough. Rakers are a little aggressive out of the box on this stuff for the battery saws. Probably wouldn't notice on a gas saw, but there's a lot of chatter. Once I grind them for the second time, the cutting corner is low enough that the raker isn't over feeding it, and it's nice and smooth.
For the price and the fact that they have full chisel in 3/8LP .043 gauge, I'm happy with the 25' roll I bought. I don't see going through it any time real soon, since I only have 2 saws that run it, and they don't get the run time that my full size saws do, but I'd buy it again.
3:31 PM
Whatcha got there Steve?
166
Habada
3:31 PM
Greenwich, NY
This...
AuerX
Constantly Confused
3:31 PM
North East
I ran prototype stuff two years ago. Now have production product.
It's faster
It's smoother
It takes less power to cut which saves battery life and will give a gas saw more power.
Glad to see efficient advancements in this tech.
Would like to see the actual battery times compared between the Oregon and say Archer chain that this thread is about.
I wonder if it's a big enough difference to matter.
166
Habada
3:31 PM
Greenwich, NY
I recently converted a Makita XCU06 18v 10" top handle to a 10" Nano setup. The customer couldn't believe the difference.
He would overload the motor with the 10" 90PX setup. With Nano the motor never shutdown and had a big increase increase in battery life.
tek9tim
12:31 PM
Winthrop, WA
Yeah that would be really interesting, whether the more efficient chain chassis (.325 lo-pro) or the more efficient cutter (full chisel) would win.
dahmer
3:31 PM
Ellwood City, PA
I switched my Echo 490 from its original .325 chain to a 3/8lp set up. No solid time numbers but the new 3/8lp set up cuts much faster.
Nutball
2:31 PM
Mt. Juliet, TN
I will not get Archer chain again until I have a chain grinder. As usual, cheap Chinese stuff requires a bit of finish work before use. I often find Archer gets Chrome where it doesn't belong: on the depth gauges & under the top plate. It's not good when you start filing a chain and realize you have to leave random cutters and DG's dull & unfiled.
3:31 PM
I touched up mine just fine.
