Anyone ever try Startron fuel stabilizer?
ft. churchill
5:28 PM
Along the '49 trail in Nevada
I've recently tried startron stabilizer in my fuel. I'm adding 2 oz. to 5 gallons of 91 octane premium gasoline which also has 10% ethanol.
I have not noticed any difference in my saws at all. What say you folks?
Backtroller
7:28 PM
Land of Badgers
I don't have first hand experience using it with saws, but I have run it in my 2 stroke Mariner outboard. I don't know if it made a difference since I think that motor would run on kerosene if needed.
jrsdws
7:28 PM
I don't use any stabilizer in my saw fuel. If it sits around too long I dump it in a car or the garden tractor and mix some fresh in with it. In the generator and the Harley for storage, however, I'll use Marvel Mystery Oil or Stabil.
HuskyHill
8:28 PM
pa
I have been using Startron for several years in all my small engine fleet including my saws, mowers, splitter and generators and I have not had a problem with it and it seems to neutralize the dang ethanol problems. I do try to rotate the supply of gas I keep for generators etc by dumping into my pickup every three months or so if not used by then. I wish I had a local source for non ethanol gas
Marshy
WFO Cutting
8:28 PM
Mexico NY
I think the whole point of using it is so the ethanol doesn't separate. If it's working properly you won't notice a thing.
wildroamer
Winning!
8:28 PM
Vermont
Marine Stabil here. Supposedly better than regular Stabil. I don't know if it is or isn't, but it's more expensive, so I buy it. I'm not a idiot.
wildroamer
Winning!
8:28 PM
Vermont
As an FYI, was just told by guy who replaced the carb in generator, that simply running it out of gas isn't enough for longer term storage. He said problem is that the little bit left in carb evaporates and leaves varnish.
Not sure.
wildroamer
Winning!
8:28 PM
Vermont
He recommends running it once a month, and if can't do that, run it dry. Then add a can or two of that canned stuff, start it up, let it run for 5 minutes, should be good to go.
Marshy
WFO Cutting
8:28 PM
Mexico NY
Some small 4 stroke engines have a spring loaded popet valve in the bottom of the carb bowl. Just shut the gas off, get a yogert cup or soup can and drain the bowl. My tillers have one and so does my blower. Best to just drain the bowl IMO.
trooney
Admitted Woodaholic
8:28 PM
The land of pleasant living
I've used Startron for years mostly in the snowblower and generator. The generator I like to fire up once in a while and the snowblower gets work in the winter. Put startron in it let it run for awhile and we're good to go til next year. I do rotate my gas and generally don't let anything sit for longer than 3 months. Also run 91 non-ethanol fuel.
Marshy
WFO Cutting
8:28 PM
Mexico NY
I'm going to go check there bottle that I have. Last I recall it said it wasn't a stabilizer.
Terry Hennessy
7:28 PM
Memphis, TN
Look up your area at www.pure-gas.org; you may find a local you did not know about. I found 1 within 3-miles and 4 more within 10-miles
Gary Courtney
7:28 PM
Froglevel
I have found Stabil to do just as it says! Put in generator and did not crank for at least 3 years and turned gas on and choked ,fired up 3rd. pull run flawlessly. I always turn gas off and let engine run out of gas when I am through using equip.
Shanks
Happy little lumberjack
8:28 PM
Beaver Falls pa
It works by keeping the ethanol in the gas.helps prevent phase separation and moisture from saturating the ethanol. I've noticed that if I don't use it I have trouble starting saws after a month or 2.
Marshy
WFO Cutting
8:28 PM
Mexico NY
I looked and it does not say that it is or isnt a stablizer. It says specifically that it is to prevent phase separation.
chainsawman2011
8:28 PM
Michigan
I use it all the time works good
