Any Chinese chainsaw and chinese parts discussion
Whitty21
11:45 PM
Ontario, Canada
You're saw looks much like mine with the plastic boot ring.
The huztls are metal .
Mine were clearly misspelled but i have seen a few like you'res.
Where they tried to fool people.
I never have and leave the incorrectly spelled badge's on mine lol
Are you going to upgrade to a 372 topend.
It really wake's those saw's up.View attachment 77049
hey, at leas it appears they actually riveted yours.
I have so many irons in the fire at this point, and this is the furthest from the fire. Maybe I will do something with it some day, maybe I will just flog it
11:45 PM
I beat the hell out of mine every time i cut.
Hopefully you have the same luck.
They are cake to mod when you get a chance.
11:45 PM
Noticed the compression was getting soft.
It's dropped around 15 pound's since i built it with the 268 cut down piston.
Compared against a new 1.5 268/37220170709_170328.jpg 20170709_170100.jpg 20170709_163556.jpg caber ring it has been losing tension.
Pics might not be clear but the caber is much larger.
11:45 PM
Piston is fine i wiped the carbon off.
Everything was coated nicely with ra.20170709_165421.jpg 20170709_165307.jpg 20170709_165129.jpg 20170709_164957.jpg 20170709_164518.jpg
No scuffs or streaks in the cylinder
That's the original straw colored wrist pin bearing that was in the saw.
I've got oem bearings on order.
11:45 PM
20170709_161646.jpg 20170709_164159.jpg I was having a problem with this filter i put on.
It's the wrong type i know
I was waiting on a husky style to arrive.
After awhile it was starving the saw it doesn't flow enough.
11:45 PM
Compared against a new 1.5 268/372View attachment 77641 View attachment 77642 View attachment 77643 caber ring it has been losing tension.
My new gauge sucks lolView attachment 77644
Forgot to mention it was the huztl ring.
In this application it wouldn't have lasted like other huztls I've used.
I've got a three year old 257 husky build that's still got good compression.
And several other saw's that are still doing great with the china rings.
11:45 PM
Planning on popups if that doesn't work out with the guy making them.20170709_204942.jpg i'm going to cut the 268 pistons down more.
To eliminate the base gasket i'm happy with how they run just trying for more compression.
11:45 PM
Thanks guys, can get a farmertec one here for less than £20 so I think I'll go that route, not that bothered in modding the carb, quite happy with a muffler mod and base delete atm. With a 268 piston in the pipeline. Thanks I will try one. TBH I have had no problems with any farmertec parts I have ever had.
Cheers guys, have a good day!
Did it work for you.
I'm trying to find a 385 carb to to try out.
11:45 PM
I tried several time's to buy an all green 372 but they won't ship to the usa.
Must've made them mad it's not on their website anymore lol
Check out this electric chainsaw.YG-Newest-chainsaw-gasoline-chain-saw-Exporter.jpg_640x640.jpg
Adamski
Plebus Splederns
4:45 AM
Essex, UK
Still hasn't arrived... But on a positive side a found the major leak on the carb. It was leaking out of the small 'choke shaft' return spring hole that is in the main casting.. It was leaking air in, altering the revs ever so slightly from cut to cut. A bit of jb weld down the hole and then a re drill seemed to work a treat. The saw is running like new again.. I shall still swap in the china carb just to test it, then throw the walbro back in. Just wanna see if it is a viable option for a spare part now :)
11:45 PM
Found a saw i would like to try 82cc looks like a 372 platform with a retarded start assist added.
Australia ebay 187.00 us looks good.index_68_22.jpg gallery1_116_9.jpg gallery2_90_8.jpg image_a.jpg gallery4_87_7.jpg
11:45 PM
Don't know if they are true 385/390 copy's
11:45 PM
More fun... will keep an eye on this, you guys are amazing.... Is this assembled, or another kit?
Assembled ready to run the aussie seller doesn't ship to the usa i tried to buy one through aussie ebay.
That sucks i was going to buy the 82cc saw .
I can't find them anywhere but in Australia.
tp2177
11:45 PM
AL
Sent you a pm regarding this I would just post it on here but not sure how they feel about mentioning other chainsaw sites.
11:45 PM
Thank you
yes we can talk about any site or business here.
Even arboristsite lol
I appreciate it.
p61 western
Ol Mudflap
8:45 PM
GFY
I would really like to learn more about the 92cc version. I would think it's a 390 copy, and if so I would like to get one eventually.
