- 9:05 AM
- Dec 31, 2015
- East Jordan, MI
Me too. I picked up a 25' roll of it. Seems to hold up fineI've had great luck with the echo bulk line been using it for year's.
I've got 75ft of 5mm and 6mm i'm changing everything.Hey Dave, Don't forget about the impulse line, have had failures with not much time on them on these along with the fuel lines.
Huztl.net the website is much cheaper than the same stuff on ebay for some reason.I have heard that the space for the small end of the rod is a bit wide on some A M 268 pistons, I have been looking for an unwindowed piston like the one you showed, where did you get them if I may ask.
Thanks for the reply, have you noticed any of the problem I mentioned earlyer?Huztl.net the website is much cheaper than the same stuff on ebay for some reason.
I test fitted it no problem or is there something else i just checked for clearance haven't worked on it yet.Thanks for the reply, have you noticed any of the problem I mentioned earlyer?
Women cut wood here too lolThe Echo liNe is some of the best.
Went to run saw and try to get a video but a Farmers Market moved into the City wood lot...... I wasn't aboUT to put up with a hundred ol bats *b-wording at me.......
Great i want to get your impression of it.Hope to accomplish it all tomorrow. I have a modded AM carb like what came with the saw and want to try that. I also have a stock Zama C3M and I need to look if I have a smaller modded one to try also. It will be interesting to see what/if there are any differences.
Anytime.Thank You
