Any Chinese chainsaw and chinese parts discussion
3:24 AM
I just can not edit my order in Duke's webshop. Maybe I'm even more blind than I hope but just cant.
Webshop itself - well, it is different. Normally you log in, edit qtys or even delete the whole thing. Nope, not there.
Seems to me that my test order has eternal life then.
@Duke Thieroff
Any ideas?
Hulpio
DIY addict
10:24 AM
Finland
Since we are in the subject. Powerwise - what was the best PC Kit for 300 series Husqvarna in Sawsalvage.co selection?
353 Hyway rings a bell but not sure if my +50yrs old memory serves me right. Wifey has doubts...
Hulpio
DIY addict
10:24 AM
Finland
Just change qty to zero.
And you are absolutely sure that it can be done with smartphone? I follow "Finish shopping" link from reminder email. It opens your page but I can no go "in" to a order line. Can not edit quantity or delete line or whole order.
Maintenance Chief
3:24 AM
South Carolina
20240224_181314.jpg20240224_181257.jpgif you put a big bore / pop up piston kit in your G395XP then your starter pulley engagement notch is probably gonna do this. Honestly I don't think it would have been a problem with stock parts, but the 100cc top end with a bgd was an absolute bear to pull over .
I replaced the pulley with a stock one from HLSUPPLY for 29$ .
Maintenance Chief
3:24 AM
South Carolina
20240224_124724.jpg20240224_124731.jpg20240224_124740.jpgAfter running 6 tanks and bucking up so big diameter trees its finally getting better and easier to start. The D-handle certainly helps .
I was bucking up a 34" log this week and the bar got pinched ( top of the tree was in the lake,fish habitat) anyway the tractor was going to roll the tree but instead I pulled the trigger and rotated the bar and it cut itself out, thats torque.
3:24 AM
View attachment 409208View attachment 409207View attachment 409206After running 6 tanks and bucking up so big diameter trees its finally getting better and easier to start. The D-handle certainly helps .
What kind of compression did you end up with?
I haven't ran mine much yet.
qurotro
Cookie Cutter
2:24 AM
Ar
View attachment 409200View attachment 409201if you put a big bore / pop up piston kit in your G395XP then your starter pulley engagement notch is probably gonna do this. Honestly I don't think it would have been a problem with stock parts, but the 100cc top end with a bgd was an absolute bear to pull over .
That's where a decom speaks lol...
I use my decom for large saw cuz of this. Not because I'm too weak to pull. Also the plastic shaft of the starter would take less load and wear.
Maintenance Chief
3:24 AM
South Carolina
I used the decomp every time, lol.
I think the hole in the cylinder is a little bit smaller than the husqvarna counterparts.
I also immediately put an OEM 395xp decomp in it.
Spike60
3:24 AM
Ulster County, NY
Those prices are real tempting. Wonder if the 388 oil pump issue has been solved. New colors are good, but leaving the starter and clutch cover orange like neotec does looks better.
While we're at it, what is the general feeling about farmertec vs neotec?
3:24 AM
The 372XT's are shown at only $89!...Plus shipping.
I bought the g372xt g372xp and g272 and they were 154.00 each shipped to my door
I bought some g288s they were 109.00 so 174.00 shipped then
Some took 32 days some took 52 day's
I have no complaints about any of them yet they've started,run,oiled fine so far
But I haven't put much time on them
as i have my 6 year old clone 372s
I did swap out very short pull ropes on the 288s and greased all the clutch bearings
That's all I've done.
