Any 67DL .325 K095 bars out there?
Wolverine
dilligaf
4:47 AM
I had to have a 67 made to fit an 8pin on my 357&346 but realized they just don’t have the azz to pull it great. It works, yes but isn’t ideal or faster. So I went back to 7 and scrapped the idea. FWIW I was using Sugi’s on both saws. 66 wouldn’t fit 8 even with clutch off attempts.
fordf150
4:47 AM
Newcomerstown ,Ohio
Tell me more would you Nate? Where do I find this adapter? Will it allow me to run a d025 bar on a k095 saw?
k095 is 8mm studs, same as the D176 Echo mount. @Homelite410 makes adapters for D176 to D025 https://performanceoutdoorequipment.com/products/echod176-to-stihl so that solves the 67DL .063 problem but brings up the oiling/bar adjusting issue of using a D025 bar on a K095 saw, not sure how involved it is to overcome those 2 issues but I'm sure its doable and much easier than trying to find a unicorn K095 .063 67DL bar.
CR888
6:47 PM
Australia
I was in a similar situation buying about 50 loops of Stihl RM 325 063 chain which was great for my Stihls. All I did so I could use it on KO95 bars for husky was run the chain on the Stihl 063 bars for a bit, then they would fit nice in KO95 Windsor speed tip .058 bars.
