Sawrain
- 10:50 PM
- Feb 11, 2017
- South.
My theory is we are rarely using the full power. Either we don't have the gearing right so chain speed isn't optimized or we don't have an aggressive enough chain to use the power and we're just spinning wheels. It's like drag cars. Equal weight you would assume more power wins, and it often does but not always and sometimes the underdog smokes the big dog. it's all about getting that power used. You've got the driver/operator. Transmission and clutch/clutch and sprocket, and tires/chain. They all go all long way to be the first down the track or through the wood.
I agree with this, but feel specifically it is about efficient use of power.
If a saw is at full throttle and steady state rpm it will for sure be putting out the power that these (fantastic) dyno graphs here show, the work is being done.
It is up to us to optimise the gearing and chain to cut in the most Efficient manner to best utilise the power , all in the chain as they say.
If chain load isn’t enough to utilise a saws peak power, rpm will continue to climb past peak until power falls off to match the load, same as wheel spin, if you don’t lift throttle you either hit the rev limiter or revs climb past peak power until power drops to match the traction available.
