All Things 288XP
JonCT
12:25 PM
CT
I’ve been looking on CL for a while and every one I found got snatched up before I could get to it. Found this out of state and was lucky enough to find an honest seller. All original, very well maintained 1989 288xp compression checks out at 165 psi. I haven’t run it yet but I’m very happy so far.
JonCT
12:25 PM
CT
I was looking it over and noticed that someone removed the two front rubber anti-vibe mounts...is there a purpose for that? I’m going to put some back in there.
XP_Slinger
They’re Just Saws
12:25 PM
Central NY
It seems I recall that the front tank mounts weren’t installed from the factory if the big spring mount was there.
Someone smarter than me please correct me if that’s not correct.
XP_Slinger
They’re Just Saws
12:25 PM
Central NY
You are correct Josh, most saws have a screw with a square nut on the front 2 AV if they have the 7th mount, but I always add 2 rubber mounts on mine, I prefer the other 4 to be spring.
Thanks for confirming Dustin. I added the front mounts when I rebuilt mine as well. Rubber all around for mine, I like the feel of it.
PA Dan
12:25 PM
White Oak PA
I want to convert mine to all rubber also. Now's a good time since I broke one of the spring mounts.
I'll do the same thing and will also be a good time since I sold my old tank with all the springs in it. The new tank will get all new rubber mounts.
