All Things 288XP
markds2
9:10 AM
Nelson, New Zealand
Hooray 288
Give it a workout this morning
Neighbor hired me to get rid of this oak
Sent from Hoskey hilltop
288 been ported?
ryan a
5:10 PM
Philadelphia,pa
So I picked up this dirty 181 for $100. Couldn’t fine and OEM fuel line with the grommet so had to pick up an aftermarket line. I took off the tank and cannot fathom how to get the line inside the tank with out jeoprodizing the rubber fuel line. I tried the weed eater line with no luck. Any tips/tricks? I can post better pics when I get home from work.
A1A7B8DF-EDDE-4A1C-A220-9CD91DCF916D.png 71F0E416-CB93-4311-B5CC-359E81A37349.png
5:10 PM
View attachment 313031 View attachment 313032
8" Hemostat does it every time for me
JonCraig
4:10 PM
Tennessee
I do the “pull through with hemostat” trick and clip the buggered up end of the line off.
a little WD40 or whatever oil helps it slide also.
ryan a
5:10 PM
Philadelphia,pa
I have the style that Stump Shot posted above. Both ends taper out MUCH larger than the fuel line hole itself. I can do the Husky pigtail line no issue, this one is different for the 181 though. I’ll get it, it will just take some time is all.
308007D5-7F7C-4B15-8184-D6EB2EBC36AB.jpeg B327FFFF-F4E0-4364-B1DB-A2B5041250B8.jpeg
Kiwioilboiler
346 Pic Examiner
9:10 AM
Marsden Pt, NZ
View attachment 313060 View attachment 313061
Excuse my ignorance, but even if you do get a flared end thru that tank hole, will it be any chance to accept that grommet?
I have to do my 288 at some point so I'm all in interested here.
Member
4:10 PM
how57
It’s a city! Not a smoke!
2:10 PM
Weed Ca.
I used a 372 hose one time. It’s a little skinnier. But seemed to work.
raumati01
9:10 AM
New Zealand
I have used those lines and just drilled a larger hole slightly smaller than the size of the centre part that replaces the grommet .
Frank bierce
2:10 PM
View attachment 316282 So it looks like the Farmertec/Holzforma offshore 288’s are available for order.
I wonder what this will do for demand and values for OEM’s 181/281/288’s.
I don’t think it will have too much effect on OEM for the majority. May be fun to put one or two together…but most know the inconsistency in quality on these kits.
decableguy2000
5:10 PM
WNC
As was just getting ready to ask if anyone else seen that ad for the Farmertech. It's been harder to find good crank cases to work with.
They don't have cases listed as a stand alone item yet, but a whole kit for now.
