All Things 288XP
stihl here
9:24 AM
usa
Not to mention the throttle arm is broke off!
Yea, there are some problems with the listing and I can use my throttle arm if needed.
If I get a good tank I'll be happy.
The title says "Husqvarna Genuine OEM Part Tank Cpl 501809105"
That's got to mean something.
Will post the outcome of this.
markds2
2:24 AM
Nelson, New Zealand
Disciple of Monkey's
8:24 AM
Stumpshot hooked me up with a cherry KS 281 jug. Super thankful to find such a rare gem. Did some horse traden with dave and getting one of those wiseco pistons for it, the 1.2 mm ring version. Trying that with a dp muffler for now. Best 281 I've ran had a ks jug and a 181 thin ring piston in it, I hope the single 1.2 ring will be close to duplicating that saw
Nope, just my puny port job which is just a little mod to the intake port, open the exhaust up and base gasket delete.
Take a look at how wide the piston windows are and how wide the lowers compare.
PA Dan
9:24 AM
White Oak PA
So i need to order a Meteor piston for my 281, seems the 52mm pistons i find online all quote a different part number.
Were there just different part numbers or did the part itself change over time.piston is needed for this saw.
I found an oem piston cheap on ebay by searching the part number. Can't remember what that number was.
8:24 AM
So what is that supposed to tell me?
Once you take a look at it and compare you will see the Wiseco is a full circle piston, the entire fuel charge has to go through the windows. So, do you want the fuel/air mix to hit the cylinder wall and then bend around or go straight into the transfer tunnel?
8:24 AM
Meteor shows three part numbers:
PC1647A 51.96 MM
PC1647B 51.97 MM
PC1647C 51.98 MM
8:24 AM
Thanks for that, when i said numbers i meant husqvarna part numbers, ive seen atleast 5 different part numbers for the 281 piston
It went through some changes over time. There was a full circle version early on. Different rings etc. and so on.
Look at the newest IPL for the latest version.
Funky sawman
Pony Power
6:24 AM
North idaho
Well running it daily now, and it's just as strong if not stronger than a non full skirt oem piston. Main difference is the acceleration is quicker.
XP_Slinger
They’re Just Saws
9:24 AM
Central NY
Now, for general interest, although you can use a 288 crank in a 394, you can't go the other way around as the 394 crank measures 69mm over the lobes compared to 68mm for the 288. My only 288 crank had a suspect big end but I had a very good 394 crank... the solution was to relieve the cases:
I didn’t know there was any difference between the 2 cranks. Good stuff.
srcarr52
9:24 AM
Iowa City
Early 394 cranks were heaver therefore larger counterweights. They only did the a couple years in the early ninety's
Most of the 394's I've checked have had cranks identical to the 288, right down to the part number.
