raumati01
- 10:33 AM
- Jan 18, 2016
- New Zealand
Is that the one on tardme?
YepIs that the one on tardme?
I believe I brought an MS200T off you Andrew, back in September '19?Is that the one on tardme?
Being the case is nearly identical couldn’t you drill a small hole for the ground screw and use a 288 switch? I’ve never had a 181 on my bench, could be way off.What are my kill switch options for a 181? There is no screw grounding it out like a 288?
Yep, it fixed up nice. Carby was the most difficult to get right tho.Just checked, yep that was me. How did you get on with it?
I vote run it. What good does it do sitting on a shelf?Working on a thin ring 181 project. Just a refresh /rebuild. Have all the parts on order. The question is should I hide the thin ring piston away as rings are NLA and use a Meteor single ring?
Yep, certainly am, Andrew. Just depends what it bids up to. Are you wanting to go for it? If so, quite happy for you to!@Kiwioilboiler @markds2 are you looking at this one?
https://www.trademe.co.nz/home-livi...id=rmlms-e413bcf45f534915a6d1bfe84758bcf1-001
nah, i'm good thanx. Got a HiTop i don't need already.....did fwd link to Mark when it first listed tho!@Kiwioilboiler @markds2 are you looking at this one?
Safe from me, I don't do Stihl.I’ve still got those 288s I bought to work through so I’ll pass .
also I’m keeping my eye on the 056 super parts saw , there’s a quite a few parts Id like off it if the price doesn’t go crazy .
Go for it bro...I had an 045 once, great old saw!I’ve still got those 288s I bought to work through so I’ll pass .
It'll take a monumental shift in Stihl service in my locale bro....yet.......
