A little 394 build...
jacob j.
Only the weird
8:18 PM
Coastal Oregon
More progress on this project: Dave's intake block (on the left) has a pretty good crack in it, so I'll be using the block on the right.
This is a pretty common problem with these 394 intake blocks - so much so that Husqvarna came out with an "improved" block
later in the series.
p61 western
Ol Mudflap
8:18 PM
GFY
Reminds me of the Pioneer Reed blocks. They are usually cracked as well.
jacob j.
Only the weird
8:18 PM
Coastal Oregon
The muffler I have for this saw is one Saw-King gave me years ago, it's got a second outlet brazed on. This is an early 394 large outlet muffler with the
bolt-on deflector and these don't really need much modding - if you see one of these in good condition, it's a good muffler for a 395 - stock or modded.
They breathe well and are a little beefier than the newer mufflers. It's another thing from an era when saw manufacturers were making parts better than
they needed to.
jacob j.
Only the weird
8:18 PM
Coastal Oregon
I spent quite a bit of time this weekend cleaning up Dave's cylinder. The numbers in this thing aren't looking promising - the squish is currently
sitting at around .035", the intake is opening around 82 degrees after BDC, and the exhaust is opening around 97-98 degrees after TDC. Blow-down
is currently around 23 degrees. The exhaust and intake ports are huge - almost big enough for me to fit my thumb through (rule of thumb). The
ports did clean up nicely and the only real flaw on the cylinder wall is a chatter mark from where the builder was roughing in the lower transfers.
I think the uppers were done with a Dremel, so I used a Craytex bit to smooth all that out. I put a pretty decent bevel around the exhaust, intake, and upper trans, and did some fine sanding
by hand.
jacob j.
Only the weird
8:18 PM
Coastal Oregon
The lower OEM ring on Dave's piston was still in real good shape and within spec, the upper ring had too much wear. I went with a new Caber on the upper. The piston
is still a good fit to the bore and I'm convinced it's not the original piston, although it is OEM.
Mattyo
Youtube speciawist
11:18 PM
Farmington, CT
Run the kill switch wire different than stock.
Dont run it under that gray throttle insert...it pinches with the case. Run it through that 1/4" hole under that gray insert and up through the carb box near the kill switch. There is a spot for a knockout under the kill switch at the base of the carb box. Drill it out :) run wire. No more pinched wires. :)
Nice idea on the lock washers for the tank limiters :)
jacob j.
Only the weird
8:18 PM
Coastal Oregon
Great idea on the wire routing - I've noticed the wire usually gets pinched where it runs through the grommet for the carb adjustment screws.
Usually by the time one of us is tearing into a saw for a rebuild, that wire has hardened due to heat and fuel exposure. I just make my own
out of bulk wire and crimp connectors.
srcarr52
11:18 PM
Iowa City
If you run the wire under the air dam from that hole up to the gray adjuster grommet, like the factory did, the wire no longer gets pinched.
Mattyo
Youtube speciawist
11:18 PM
Farmington, CT
I've never seen a wire not pinched. When it's run under that insert it gets pinched. I'll look for the route you mention next time I'm into one.
