85cc 064 porting
Chainsaw Jim
Con Artist LLC
9:05 PM
Springfield Oregon
Hmmmm......I have three 064's here at the moment, and they all look like this:
The limited coils look the one Jason shows, and the unlimited look like a plain 029 style coil, which is what I use for replacements, they're cheap!
I was wondering that after i left the comment. I figured it would be my luck to have that be the case. I could have just looked at one of my own damn pics or cases but no...I decided to play stupid instead. Lol
I actually have both types and am obviously more familiarized with the one in the first pic.
Red97
12:05 AM
MI
These stihls a 12mm piston pin or 13?
Meteor lists the 281 as 13mm curious for future reference..
Split the difference go 025?
Nice build ya got going..
Chainsaw Jim
Con Artist LLC
9:05 PM
Springfield Oregon
The 064/066/660 pistons are 12mm wrist pins. The Husqvarnas are 13.
But the rod ends are the same exact diameter. You use the bearing from the 281 piston.
Chainsaw Jim
Con Artist LLC
9:05 PM
Springfield Oregon
They have a 12mm pin. Use a 880 pin bearing and a couple custom made washers with a 281 piston.
The 394 bearing is wider and doesn't travel beetween the bosses. The cylinder holds the piston centered from side to side travel so everything stays put without extra parts.
BuckthornBonnie
12:05 AM
Penn Yan, NY
I have two 064s that were originally limited. I built them up using an 046 coil and a 1201a flywheel.
Has anyone tried the aftermarket dogleg coil? I just might give it a whirl on my next 064 build.
Edit- both saws have a Bing carb, too.
Glock37
12:05 AM
Monroeville Pa
After reading through 20 odd pages of threads and going over a bunch of tech notes and IPLs I put this together hopefully it is helpful to somebody. The many fine folks here were invaluable in helping me understand as much of this as I can absorb so far :)
Pictures at the bottom of the post and corrections/additions welcome.
Thanks to Jacob J for the tons of good info on this topic.
Also attached is some interesting 064/066 documentation in a PDF that I hadn't seen here before.
064 / 066 / MS640 / MS650 / MS660 Ignition Systems V1.0 6.25.15
Earliest illustrated parts list noted where known.
Flywheels – aluminum with single keyway unless noted.
1122 400 1201A – 064 for use with Bosch ignition, unlimited coils
1122 400 1202 – 066W, MS660 for generator
1122 400 1203 - 064, 064R for use with limited coils 1303 [92.12ipl]
1122 400 1203 (double keyway) - 064, 064R for use with limited or unlimited coils
1122 400 1203/1204 - marked with both but only one keyway, normally limited
1122 400 1204 (single keyway) – 064 for use with limited coils ONLY
1122 400 1204 (double keyway) – 064
1122 400 1206 – 064 for generator 3500 [87.1ipl]
1122 400 1207 - 064W for generator 4000 [92.12ipl] and generator 3500 [95.01ipl]
1122 400 1209 - 066
1122 400 1209/1214 - 066 marked with both but only one keyway
1122 400 1209/1214 – 066 double keyway
1122 400 1214 - 066, 066M with larger big end bearing from early 1995 [95.01ipl]
1122 400 1215 – 066 redeye
1122 400 1216 - 066W heated handles [95.01ipl]
1122 400 1217P – 066 pre 1996 poly
1122 400 1217 – MS650, MS660
1122 400 1218 – 066W, MS660 heated handles
Generators
1118 400 4000 – 064W [92.12ipl]
1122 400 3500 – 064W [87.1ipl], 066W [95.01ipl]
1122 400 3501 – 066W, MS660
1122 400 3502 – 066W, MS660
Ignition Coils
0000 400 1300 – 066 unlimited “short” mount
1122 400 1300 – 064, MS640 unlimited, “dogleg” mount, works with generator 3500 [87.1ipl]
1122 400 1303 – 064 CDIC limited Prufex [92.12ipl]
1122 400 1307 – 066 CDIC-A limited including 066 red eye model
1122 400 1311 – 064/066 unlimited, easier starting, short life span [95.01ipl]
1122 400 1312 - 066 poly flywheel three screw mount
1122 400 1314 – 066, MS650, MS660 two screw mount
Trigger Units
No number shown - 064 September 1987 to mar 3rd 1991 [92.12ipl]
There are at least two version of the 064 crankcase with different mounting holes for the ignition coils.
QUESTION - I have a flywheel 1203/1204 with a single keyway, when I line up the magnets with a dual keyway 1203 flywheel the single keyway lines up with the 1:00 keyway rather than the 12:00 keyway when viewed from the outboard side. So is this a limited or unlimited flywheel??
Thanks
Dave
44.86 is instructions for stocking parts for the new 064 models
43.86 is an introduction to the new 064 models with all the technical specs, etc.
