Redfin
Meh...
- 3:58 AM
- Dec 24, 2015
- Central Pa
If ya gots the skirts to cover...I thought my 394 was wide but damn.
Yeah probably that!!!Because it’s a stihl and they can. Lol
Husky plating is more like nikasil and much better.
That’s the only scored cylinder I haven’t been able to save. One tiny little mark and I sanded through in about 10 secondsUnless its on a 359. For some reason it is very thin on that model.
Well there ya went and did itHusky plating is more like nikasil and much better.
Just finding that out recently myself. These 394 pistons get destroyed from poor port work with no chamfers on the windows, sad. The plating still looks like new in this jug. Hacked it up some more.Husky plating is more like nikasil and much better.
Uhh... what’s a 285?Just finding that out recently myself. These 394 pistons get destroyed from poor port work with no chamfers on the windows, sad. The plating still looks like new in this jug. Hacked it up some more.
Only cleaned up one other Husky 372 saw. The jug that crossed my bench burnt some years back. Put a Meteor kit it.
Do you stroked hooligans think cutting off the counterweight some on this 285 crank will run well in the 394 case?
Looking for 0.030 in there or more. Don't want to cut much if any from the cases. This crank needs a diet plan beyond the norm. I'll have it shot peened if needed.
Thoughts...
Not disagreeing at all, be we are going above and beyond regular ported worksaws. And to do that, you will be plating a cylinder.That may be true, but I have never met a builder who did not prefer OEM cylinders on their Stihl ported saws.
And with Stihl or Meteor pistons, they seem to provide very good service life.
I totally agree, I know several builders who insist on an OEM jug being sent out and re-plated (preferably by Millenium) before they will accept a saw to build. In addition to the superior plating they are also more meticulous and hone a straighter bore than OEM. If you are fighting for 1/1000th of a second, you do what has been proven to make a positive differenceOEM bored out and plated is the only way to go.
Eight so farHow many you got now?
Yep skirt length and compression height are identical to OEM, while the skirt width and other specs are quite differentGranted these are forged pistons that DDawg had produced (snip), I do believe the comp height and skirts are oem. DD can verify.View attachment 274335
Depending on the original plating and the intended use there are a lot of coatings and linings that can be used, Nikasil or a similar HARD plating is required to run chrome-faced steel rings like NPR.I thought I read that the bored out jugs were sent out to get chrome lined? Am I mistaken?
Regardless of who bores the jug, I send them out to Millenium (for two piece cylinders) or US Chrome (standard one piece cylinders), there is a place in Europe, but I need to find the info on them again.Where do these bored jugs get sent then? Is it nikasil coated like oem?
Stihl plating is proprietary, more like chrome than nikasil from what I understand.
@Definitive Dave knows all about it.
I still don't quite understand why they use such a proprietary blend, it's not really chrome but not nikasil either.
The Short Version:Husky plating is more like nikasil and much better.
What ever they are doing, it obviously works! OEM jugs are sought after!
That may be true, but I have never met a builder who did not prefer OEM cylinders on their Stihl ported saws. (snip)
The weight of a crank, in conjunction with the balance is a can of worms best left for specialists in my opinion. When we have them stroked for the 3140xp Husky pipe saws, Crankworks does a LOT of different tasks in making the crank perfect. A race saw NEEDS a balanced crank, whether it is stock, stroked, ported or a full circle build. Again when you are looking for 1/1000th, you go where it livesDo you stroked hooligans think cutting off the counterweight some on this 285 crank will run well in the 394 case?
Looking for 0.030 in there or more. Don't want to cut much if any from the cases. This crank needs a diet plan beyond the norm. I'll have it shot peened if needed. Thoughts...
This is where Fun lives!!Not disagreeing at all, be we are going above and beyond regular ported worksaws. And to do that, you will be plating a cylinder.
This makes me weep, broNone of my are, or will be, beyond woods port.
