- 7:16 PM
- Aug 2, 2017
- Chicagoland, Illinois
JMS Involved?
(Sorry, just had to.... )
Dang if that dont look like a roller bearing
I'd cut the chamber to clean her up, then cut the base for 0.019 squish with the gasket. Slap in a new piston after carefully making sure the wrist pin bearing aint missing a roller
check both the wrist pin bearing and the con rod bearing, that looks to be marks from a roller.Something has been swallowed... View attachment 94959View attachment 94960
And the ring is stuck solid in the groove..
But the bore is clean.. can this cylinder be salvaged and get a new piston kit. Not sure what it has swallowed as the needle bearings are all sweet as.
Unfortantly, I've seen to many blown conrods bearings on them 550's.
most of the times when a piece come from the bottom part it hit one of the transfer ports, if them ports and piston sides are prestine maybe them fools dumped down a pin through the plug hole.....I’ve just been looking with a torch and a pick every pin. I can’t see one missing or witness marks of one popping between the cage and the crank lobes.. perplexing me this is
Them main bearings has nylon cage, I thought when I saw the pictures that its part of a roller, hopefully I'm wrong
That scenario makes sense.I’m starting to think the previous owners used some sort of hard wire as a piston stop and chobbled the end off in the cylinder and left it. And screwed it up that way?
yup, its defently possible, we have seen people using piston stopper through the exhaust portI’m starting to think the previous owners used some sort of hard wire as a piston stop and chobbled the end off in the cylinder and left it. And screwed it up that way?
The pictures I saw made me think about a roller, but the marks are so big that it pretty much has to be a full roller, and that you should easily rule out, doubt a roller can fly through the whole system without toutching a transfer port.
Since the muffler threads was ripped on one of the sides, was the muffler loose?
The sad part is, the piston kit is stupid expensive.Dang if that dont look like a roller bearing
It's makes more sense to get the cylinder kit to me. Unless you are really pinching pennys.
I did put a LRB piston in one 550 and it was a decent replacement for the money.
