395xp build..then OEM vs AM shootout
Frank bierce
1:46 AM
Have had a 395xp carcass sitting for a little while. Decided to try to find the parts I need to get it put together. Surprisingly, I had some good parts that I can use. Yes, I have a 394 cylinder on there now, that’s just to keep the bottom end clean. I know I had a couple 395 cylinders...just have to locate them. Thought I knew where they were...apparently I was wrong. Lol.
My ultimate goal, is to build the saw up in OEM form, then try one of the aftermarket piston/cylinder combos to see what the difference is.
D028D5D9-DD6B-41A2-8545-DE30B1674C7C.jpeg DE51A908-4FBB-4C64-8EF1-B93489B1968E.jpeg
Frank bierce
1:46 AM
Bottom end was pretty much complete...looks like I may need a coil, or just a coil lead. Had the muffler and clutch cover. Will need to find a Recoil assembly, and some top cover pieces.
Found the cylinders...
StephK87
10:46 AM
Germany
sub'd! I have a similar plan, got this new 395xp hyway big bore popup kits from a friend (dealer) for testing. I let the BB saw compete against my oem ported 395, first stock with popup, then ported.
Looks not so bad, they have visibly improved in the last couple years
Beavis331
3:46 AM
Minnesota
Sweet! Have a project 395 on the way. Gonna follow this one. Gonna need a flywheel for it. Why are flywheels so hard to find for these?
Bullets
2:46 AM
Utah
See where the piston windows line up to them
With the Piston at BDC it looks like to match the lower with the Piston window I need to raise it nearly a 1/2 inch does that sound right it looks like a lot
