395 xp big bore porting
farminkarman
I like the red & black ones
9:48 AM
Neenah Wisconsin
Ok cool. If I take the transfers up to get a 20 blowdown will the longer duration matter?
The longer duration is what you need if you want the saw to make torque at a higher rpm.
Just wondering, to save some grinding on the cylinder upper transfers, could I grind a bit off the top piston edges to make transfers open sooner?
You can do that, but you are going to make your already loose squish even worse.
stuh
OPE Member
2:48 AM
New Zealand
Oh yes, I didn't consider that. I'll just do the cylinder.
When it comes to widening the intake and exhaust, would the best way to measure how much I can go be to put bearing blue on the piston and gently scribe a line so I know how much to take off either side?
EFSM
9:48 AM
Extreme southern IL
You can, although it lowers compression and can deflect the air flow.
stuh
OPE Member
2:48 AM
New Zealand
As I'm pretty green to this, if I have 28* blow down, how will the saw perform with a 36" bar vs a 20* blowdown with the same bar?
MG porting
7:48 AM
Wa
Here's the numbers for the bb no base gasket
Intake 102* abdc open for 152*
Exhaust 118* atdc open for 140*
Transfers 129 atdc
Squish 40 thou
OEM ,no base gasket
Intake 102 abdc duration 152
Exhaust 103 atdc duration 150
Transfers. 123 atdc
Squish 30 thou
Put the OEM cylinder on without the base gasket and do a simple muffler mod and call it a day.
thompsoncustom
9:48 AM
iowa
I'm not a pro at porting but my understanding is that more blow down will give better torque (to a curtain point) and less is higher RPM so more speed.
thompsoncustom
9:48 AM
iowa
In order to make room for the bigger bore, they have to infringe on the transfer tunnels. Kinda defeats the point of having more swept volume.
Anyone try welding up the outside of the transfers and then grinding the inside out so they are just slightly bigger than OEM?
stuh
OPE Member
2:48 AM
New Zealand
I think the heat from welding could possibly distort the cylinder a bit
thompsoncustom
9:48 AM
iowa
I've been some brazing up inside the cylinder head/dome area with success and failures(warping) but I would think that controling the heat on the transfer would be easy. Is it worth doing on the other hand IDK but if you were going to increase the bore and/or stroke seems like it would be worth it.
stuh
OPE Member
2:48 AM
New Zealand
The brazing in the cylinder head, is that to increase compression?
Ketchup
Epoxy member
8:48 AM
Colorado
Raising the lowers will help with the smaller transfers and also make a better line of flow through the piston windows. Raise the divider up into the tunnels and thin it. Smooth out the transition into the lowers but widening and enlarging doesn’t seem to help.
On the BB, you can raise the exhaust higher and leave the transfers a smidge lower. The tight transfers want more blowdown, kind of like a 7900.
Cut the popup off the piston and set your squish properly (0.025” is plenty tight). They don’t need much band cut. Anywhere you cut the plating diamond is best. Cut into the plating, not from behind it.
Make sure the muffler is wide open. 395 make a lot of heat when you raise the RPM.
stuh
OPE Member
2:48 AM
New Zealand
I took the exhaust to 100 and widened, widened the intake but left it at 79 and opened up the lower transfers ( didn't touch the uppers) I made a stainless bearclaw style pipe and the saw runs good but not as much grunt as I hoped for when bar is buried. I tried it with a 24" bar. Blowdown is 28°, if I raise the uppers to 23 or 20 degrees would it have better pull with a buried bar?
Here in NZ it seems to be hard to find 90° grinder small enough to work inside a cylinder. Any suggestions on where to buy them that would ship to New Zealand?
9:48 AM
What is a bearclaw muffler?
9:48 AM
If you buy a hand piece, I'd be happy to ship it to you.
jacob j.
Only the weird
7:48 AM
Coastal Oregon
Ketchup
Epoxy member
8:48 AM
Colorado
Yeah, I think your uppers are too low. What’s your squish? It’s worth trying the saw with a bigger bar.
