395 xp big bore porting
thompsoncustom
9:46 AM
iowa
The brazing in the cylinder head, is that to increase compression?
it was and did work but I wouldn't do it again if I was going that route it would be welding. Everyone uses a lathe and cuts the base off the cylinder and that's the right way to do it for increasing compression its only in the really out there stuff that you need to start welding in the cylinder. I haven't yet but I might cut and weld a conrod to raise the piston higher into the cylinder (no stroke increase) along with having the cylinder cut but that's for one of those crazy odd ball projects.
stuh
OPE Member
2:46 AM
New Zealand
That sounds pretty cool. I've got to make a mandrel, then I can cut bases on my lathe.
I've just been looking at my numbers for my OEM cylinder, intake is 79, exhaust 103, transfers 123 and blowdown is 20.
I'm thinking of taking the intake to 81, exhaust to 99 making blowdown 24 and widening intake, exhaust and lower transfers, squish is 29 thou and use a pop up piston.
Thoughts on those numbers?
srcarr52
10:46 AM
Iowa City
Ok thankyou, What websites would I find one on?
I ship to NZ but I'm out of handpieces at the moment. I'll have more in stock by the end of this week.
Ketchup
Epoxy member
8:46 AM
Colorado
Easy, but won’t perform as well. Machining and transfer work make a stronger saw. That’s why people do it. Buy the tool listed above. It’s excellent.
stuh
OPE Member
2:46 AM
New Zealand
So too long on transfers? More around 20° blowdown for a stronger saw? And if I machine the cylinder, would I go for a 20 thou squish
Ketchup
Epoxy member
8:46 AM
Colorado
20 blowdown but I like closer to 0.025” squish on bigger saws. They’re easier to pull and seem to spin better.
stuh
OPE Member
2:46 AM
New Zealand
Awesome, I'll see if I can get a port tool for transfers and have a crack at machining the base
