XP_Slinger
They’re Just Saws
- 5:34 PM
- Feb 9, 2016
- Central NY
Forgot to mention previously. After the carb is installed check to make sure the throttle arm has full rage of motion from the idle stop to the WOT stop. If it’s not resting on the idle stop check the cable on the trigger end, the housing is likely not seated properly in its recess.
Resting on idle stop.
Full travel to WOT stop (carb housing). Good to go.
