394XP - Work Saw Rebuild
XP_Slinger
They’re Just Saws
5:30 AM
Central NY
Forgot to mention previously. After the carb is installed check to make sure the throttle arm has full rage of motion from the idle stop to the WOT stop. If it’s not resting on the idle stop check the cable on the trigger end, the housing is likely not seated properly in its recess.
Resting on idle stop.
Full travel to WOT stop (carb housing). Good to go.
qurotro
Cookie Cutter
4:30 AM
Ar
A little advice: use a little of 1184 when install the oil line to prevent future oil leak. That's just me..
I always found those old hudky leaks from the hose surface between the case or the oil pump.
XP_Slinger
They’re Just Saws
5:30 AM
Central NY
I guess I’ve been lucky because I haven’t experienced that problem. But that’s a good fix for it provided a plugged vent isn’t the issue. Thanks for sharing
David Young
Safety First !!!!!!
5:30 AM
vt
Nice job Josh thank you for the build thread. I know they are a challenge to photograph and narrate.
also for the record. you are doing it wrong
everything wrong,wrong, wrong
XP_Slinger
They’re Just Saws
5:30 AM
Central NY
Ignition and flywheel assembly.
First install the air injection duct.
Next install flywheel then the coil with 2 fasteners and set the gap to .012. Route kill wire and spark plug wire as shown.
Shaved the key for a timing advance.
Coil took some damage when this saw got wheel chocked. OCD is telling me to replace it, but since the saw ran fine with it I’m going to run it til it fails. If this were a saw for someone else I would recommend replacement.
Last thing was some shrink wrap on the plug lead to protect some areas that are chaffing. Again, I wouldn’t bandaid this if it were for anyone other than myself.
XP_Slinger
They’re Just Saws
5:30 AM
Central NY
You caught me David, I don’t even know who these pictures belong to:risas3:
XP_Slinger
They’re Just Saws
5:30 AM
Central NY
Checked the decomp clearance in the top cover hole and it was dragging enough that it wouldn’t pop out. Shaved the hole with a razor blade (giggle) for clearance.
Squish is at .032, sucks that it won’t have good compression.
Wrong! Being that a 394 is basically a 2-series saw design, it produces good compression with fat squish because of the small combustion chamber. It blew 190psi but my gage leaked a little before I could snap the pic. Right where I like my saws.
XP_Slinger
They’re Just Saws
5:30 AM
Central NY
And the video I’m sure everyone wants, runs strong, very happy. Apologies for the constant piss revving, I check tune a lot during first cuts. Not needed but we all have our ways...lol!
In the words of my brother @RIDE-RED 350r ....
Tree - 90 - Feckin - Fo!
Will do more cuts with a longer bar...gotta find some big wood.
