372 sputters when tipped, passes spray test
EFSM
7:38 PM
Extreme southern IL
I swapped the carb to a 385 carb off my smashed XS 2175 this am and I haven’t put a bar on and put it in wood yet but the tune is stable regardless of position, side to side anyway. Nose up or down changes a little bit I think that’s normal. It doesn’t stall. I think those RWJs just kinda stink.
Interesting. From my experience, those carburetors have held up very well. I’ve worked on many a 372 and Ican’t recall even rebuilding one. Then again, I’m not working on shelf queens that live in CA.
davidwyby
Rural desert logging
5:38 PM
Extreme Southeast CA
Xp or xt?
8:38 PM
Seems healthy
Saw is almost new.
I blew it off first (desert wood is filthy dusty)
Not sure if it was sucking air there or I didn’t get it clean enough or…🤦🏻‍♂️
I put a light film of motoseal on all those contact points
Never had a leak.
Junk Meister
7:38 PM
Nebraska
Something else I’ve learned along the way. If your carb screws are normally at one and one, turn the H out 2 turns. Hold the saw wide open and if it hits the screw setting rpm for a split second and then takes off and screams, it’s a flexible leak. 90% of the time it needs new seals. That is the only way that I’ve ever been able to diagnose a seal leak for certain
You aren't walking on water - yer hydroplaning with this troubleshooting analysis. If'ns I keep reading "STUFF" like this I will either get smarter or brainwashed. Simply put this is above my pay grade ..... When you say "Flexible Leak" -- I would hope you will explain better so I don't get my foot where it doesn't belong .
8:38 PM
Flexible, meaning something that can change size depending on throttle position. There’s vacuum inside the crank case and intake boot when you’re under acceleration. The boot and seals are both rubber. If you rev a saw up to an overly rich H jet setting to intentionally hold RPMs down, a bad seal or tear in the boot will suck in and allow excess air into the crank case to mix with that extra fuel and the RPMs will scream
Junk Meister
7:38 PM
Nebraska
THANK YOU
I wasn't even close to your explanation.
Duce
8:38 PM
Roscommon, MI
372's oe or xt are easy to tear down and do complete rebuild. Clean every part, check carb screen, check bearings, base gasket (had one that blew pto side out), tank vent, fuel lines and impulse line, muffler screen, new o-ring (never seen a saw without one, pick around crank, bet you find one), replace seals and base gasket (if you want one), vacuum check, new fuel filter. Make it right once and forget it!
jacktheripper
Papa Squat
6:38 PM
Wyoming
Excellent advice
jacktheripper
Papa Squat
6:38 PM
Wyoming
It can be the carb nozzle check valve. I’ve had saws that ran fine in one orientation, but with an iffy sealing check valve, gravity can influence it to not seal correctly. Also, for some strange reason if you don’t have your metering lever or spring set right, I’ve had carbs act oddly when tilted.
MG porting
5:38 PM
Wa
Seems healthy
Saw is almost new.
I have found on the aluminum carb base tend to need some shaving around the outer lip that over hangs the portion of the intake boot that seals up against the carb.
mrxlh
I stayed late and finished!
7:38 PM
Dat Boot
I’ll bet you a $1 the RJW is just rich. My 372XT acted like this and no matter how much I fooled with it I couldn’t ever get it tuned right until I stumbled on how Walt tunes them. Like Kevin said it’s probably fuel pooling, I did the tip test after idling and just kept turning the L in a hair til it stopped doing it. Never touched it again for over a year until I traded it, the new owner never had an issue with it to date either. FWIW I did the spray test on it as well and it passed, which then made me scour the Internet for a whole evening until I stumbled on too a build of an XT someone did here.
