ZukiRyder440
Breaker of recoils
- 10:50 AM
- Apr 11, 2018
- NY
Thanks and Yes it was….. lol! Dry aged and left out in the rain toothats some speed wood right there.
sounds good tho man
Dang……. But luckily you can still get the HD 12 carb kits though.. Finding carb kits for the zama c3ms’ is interesting. Spend 3/4 of the time sifting through aftermarket stuff just to find the certain sellers don't have them in stock… yay lolWell, I put my last hd12b on the 357 with the pop up piston, this showed 199 on the comp gauge.
Carb is pouring fuel in, gonna have to pull it off & rebuild it.![]()
Red sealer?? Hmm.. have the jets been drilled out too? Just curious.Took the carb apart today, I imediatly saw the needle lever too high, bent it back to level withe the carb body.
Since every thing else looked good in there I put it back together & fired it up, no more richness! tuned on it abit to get it useable & went to the log.
I was not impressed with it yet, main jet down to about 3/4 open but still not turning the revs it should.
I think this carb has been worked on, both butterfly shafts have been milled flat & I saw more than normal red sealer inside.
I'm sure this one came off one of the 372s I put 390 carbs on, it ran fine before.
Ahh. And yeah, that looks good. Way better than my first go at thinning out shafts in one of those carbsView attachment 357734 Sealer on those little round covers inside. Don't know about drilled jets, didn't look. real nice mill job on those shafts tho.
