old guy
Love me some Husqvarna
- 6:23 PM
- Jan 21, 2016
- Becker Minnesota
Thanks Man!
Not a problemThanks Man!
No problemo and I hope you did as well, and me too lolThanks for the pics Man, that helps a lot.
Hope you had a great thanksgiving, I'm still stuffed.![]()
Thats good to hear! And, post ip some vidyas if you want to or canGot the carb on today, this saw is one I put together 2 or 3 years ago, 357 bottem with the stuffers, 359 top with transfers matched to the case, opened transfers some but did not grind out the dividers since Mr. Evans said it was better to leave them in.
I don;t remember now but I must have widend intake & exh., did base gasket delete & bigger hole in muffler.
This saw was faster than my stock 562, beating it everytime at a gtg.
It fired rite up with the new carb, seems to have a deeper roar now. Took it out to the pine log I have & let er eat, seems to have a lot more torque, but the chain was not top shape. I will sharpen the chain and if I think it will do it I'll throw on an 8 pin.
This went pretty easy after following your thread. Thanks
Awesome!!I round ground the chain which is one of those new husky chains 2nd sharpen, on an 18'' orange g b bar & took a couple more swipes off the rakers, put an 8 pin on and went to the log.
The saw did not care about an agressive chain & 8 pin, it just went wot and threw chips, I did not have to baby it one bit!![]()
I started off with an ol beat up dremel as well. Thats why i liked these 359 cylinders. Pop the caps off and grind awayI do have a ° wheel, but all I have for grinder is a flex drive dremel, so I don't get into any serious grinding.
I do have another 359 that I did grind the dividers out of, also have a 357 with a popup piston, don't remember if I ground in that or not, but I'm sure it's gasket delete & muff mod.
I have another 372 carb, Gonna do the 357 next, hafta get another choke lever tho.
I'm gonna be 82 in Feb., Sometimes don't remember what I've allready done to these saws
