357 carb on 346xp
1:02 PM
Tell me more sir. Is it something you added? A Euro thing?
A Eco thing. The original vent went to the air filter adapter as it was an epa saw. So something had to be done with the vent line also had to plug the primer bulb line just above the tank. The only eco thing left when I was done was the green fuel cap.
beaglebriar
The Peanut Gallery
2:02 PM
Warren Center, PA
I'll keep it in mind. I'm still kinda dumb and feel like working with two strokes means I'm going to smell like gas and oil occasionally.
I've had a couple customers complain about gas spilling out the vents so they get retrofitted with those.
longleaf
2:02 PM
Dot, GA
I didn’t even think about the primer bulb. Mine has one.
1:02 PM
You could can the primer bulb and put a frog skin over the hole
I thought of that, it just didn't work out, kind of a goofy hole and nothing sticks on the Jonny top. :(
Edit: That and I didn't want to screw up the air injection feature as I recall.
Tor R
Novice, Leg model #2
8:02 PM
Mandal
You gotta trim the carb floor for a proper fit with the 357 intake.
+1
the easiest solution is to use one OE top cover.
Personally I dont care so much about it, blocking the lines and its good enough for me
blsnelling
Friend of the Riff Raff
2:02 PM
Franklin, OH
I use the COMPLETE 357 intake tract, from the boot to the air filter.
I use a 390 clamp. I despise the metal clamp that Husky uses.
I gut the internals of the stock tank vent and use the Echo vent.
I have never modified the carb box floor.
I remove the purge bulb and use an OE cylinder cover.
