346XP Rebuild
Tor R
Novice, Leg model #2
1:27 AM
Mandal
I just shave off those plastic clamp pieces and dump one metal clamp on all those 346/357 I have. I've seen to many scored pistons with those old stupid plastic clamp.
Definitive Dave
Piss Rev Mafia Member
7:27 PM
Central Ohio
Like this?
glad to see you experimenting with assymetric piston geometry, I am sure you will garner significant gains in torque and speed with this build, but I am guessing machining the cylinder to match the piston will be time consuming, bravo and huzzah!!
Stihlbro
7:27 PM
Virginia
Not a very good picture. You can not put the screw side to flywheel side as it will hit the case. It will not clear cylinder fins in the 12 o'clock position. Installed in the above picture is done prior to setting jug, even before upper spring is installed.
Hope this helps.
redoakneck
7:27 PM
Ohio326
Hope this helps.
Did u cut the old plastic off or just go over the outside of it??? I cut the whole plastic ring off and used that exact same clamp ( from 031?) And it clears it at 12 o'clock on the cylinder. I haven't put it on the case yet, but it is assembled. Thanks for the heads up on putting in so screw can be accessed from PTO side
Stihlbro
7:27 PM
Virginia
Just the plastic part that locks. I left the rest as part of it makes up the impulse nipple. To me it makes it more rigid. With what you done there is likely ample clearance. Keep an eye at the impulse area.
redoakneck
7:27 PM
Ohio326
Is that 357/359 plastic intake piece with the impulse nipple really no longer available??? As is the rubber boot according to parts tree???
redoakneck
7:27 PM
Ohio326
Might use some motoseal between the boot and plastic partition.???
That area doesn't flex with the av?? Does it???
Not at shop, try to remember???
This brain I have is too old, need a newer with more gigs!!
Tor R
1:27 AM
Mandal
is avaible, lots have got new numbers
beaglebriar
The Peanut Gallery
7:27 PM
Warren Center, PA
I ran into this not long ago with a common part. Sent a few PM's asking where to locate parts. Turns out the part number was updated. I felt like a dumba$$.
Tor R
1:27 AM
Mandal
